VA_Wheeler 0 #1 Posted July 31, 2011 This is my first post. I just acquired a 1976 C-120 with a 36" rear discharge mower deck. Overall the tractor is in fairly good condition. It needs new front tires and a new battery, it weak when starting. However the one issue I have is, when I go to engage the PTO lever, the engine bogs down and begins to die. If I release the PTO the engine runs right back up. Any suggestions? Here is all the info I have on my Tractor, any more insight will be appreciated. Model: 61-12K802-10685 Serial: 6028 Deck: 65-36XR01-06453 Engine: Kohler K301S 12 HP Share this post Link to post Share on other sites
rmaynard 15,801 #2 Posted July 31, 2011 :woohoo: Sounds to me like either the mule drive pulleys are binding, or the spindles on the deck are binding. With the engine off, check to see if the blade turn freely, and if the mule drive is binding. Share this post Link to post Share on other sites
stevasaurus 22,968 #3 Posted July 31, 2011 :ROTF: That is one nice looking horse. Along with what Bob said, should have grease fittings on the deck spindles...could just have been sitting for a while, and needs to just run...you should have your throttle above half to full when you engage the PTO. After you run her for a while, carefully check to see if any pulleys get hot. :D Share this post Link to post Share on other sites
earlleecliffton 38 #4 Posted July 31, 2011 :woohoo: Share this post Link to post Share on other sites
C-Series14 15 #6 Posted July 31, 2011 First off welcome...And to avoid further confusion, the deck tag is on the tractor for some reason! Share this post Link to post Share on other sites
redhorse47 0 #8 Posted August 1, 2011 Try a jumper on the seat safety switch. Welcome to Red Square. Share this post Link to post Share on other sites
chazm 413 #9 Posted August 1, 2011 Hello & Chaz :woohoo: Share this post Link to post Share on other sites
tunahead72 2,485 #10 Posted August 1, 2011 Good evening, and Can we assume you're located in Virginia? If so, whereabouts? That's a nice looking tractor you got, hope it works well for you! There's been some other threads recently about the "engine wants to die when I engage the PTO" problem. You might want to read through this one for some ideas, although I'm not sure it was completely resolved: http://www.wheelhorseforum.com/index.php?showtopic=29094 I thought I'd seen at least one other recently, but I couldn't find it just now, anybody else know where it might be, or was I imagining things again? What's wrong with the front tires? In one of the photos, it looks like maybe the sidewalls are a little chewed up, do they hold air? By the way (and I'm no expert on these), if I'm reading your tractor numbers correctly, I believe 10685 is the serial number, and 6028 is the build date (28th day of 1976, which I understand is the scheduled build date, not necessarily the actual build date). Share this post Link to post Share on other sites
SAM58 30 #12 Posted August 2, 2011 Hello and I could be wrong, but it looks like the belt is on the wrong pulley on the clutch. The deck belt goes on the inside pulley closest to the engine. That will cause more stress on the engine. By the way, that deck will not have grease fittings on the spindles, they are sealed... If they get tight, you will have to replace them. Share this post Link to post Share on other sites
C-Series14 15 #13 Posted August 2, 2011 Also looks like the lower belt is flipped. Is there a flat idler pulley on the outside of the front mule drive? Share this post Link to post Share on other sites
