Raider12 14 #1 Posted July 31, 2011 My Raider 12's transmission (5073) has a mlot of wear and tear on it over the years and has held up quite well. But it's time to freshen things up. I have another 8 speed on the shelf that I believe came out of a C-120 from the early to mid 70's (5091) Are there any BIG differences between the two of them? I know the 5073 is the "limited slip" and has 10 pinion diff. But other than this, any reason I can't swap this 5091 right into my Raider? Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #2 Posted July 31, 2011 It should be a a direct swap. :woohoo: Share this post Link to post Share on other sites
Raider12 14 #3 Posted July 31, 2011 It should be a a direct swap. Are there any way to positivly ID the doner transmission? As look through the model list there are a few different 8 speed transmissions. Will they all use the same seals and axle bearings etc? Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #4 Posted July 31, 2011 They're almost impossible to ID unless you have or know the tractor it came out of - and that doesn't always "hold water" if you don't know the history of the machine. (could have been swapped before) Seals and bearings were identical between many 8 speed models. It's hard to tell what you have / need without seeing it though. :woohoo: Share this post Link to post Share on other sites
littleredrider 409 #5 Posted July 31, 2011 I swapped 8-speeds into two different lawn rangers. If it's nearly a bolt on for those, it should for yours!!!! :woohoo: Share this post Link to post Share on other sites
Raider12 14 #6 Posted July 31, 2011 The transmission I want to use, I also wanted to freshen it up first> New seals and gasket etc before installing it. I will take pic and see if there is any way to figure out what model it came out of. Share this post Link to post Share on other sites
stevasaurus 23,816 #7 Posted July 31, 2011 Raider...should work for you. Post pictures when you tear them down...we may be able to ID the trans or at least narrow it down. I know of 3 things to look for when swapping transmissions... 1. measure the distance of the mounting bolt holes. 2. the brake drum shaft comes out of the same spot on the transmission cases. 3. axle thickness & length. If the above 3 things are the same, you are looking at a bolt on swap...and the bearings and seals should be the same If you have any differences, you can still make it work, but will require some modifications. Some of the gears will be common in both transmissions. Don't quote me on this, but I have a theory that I have not tried yet. If the bull gears are the same...the big gear in the center of the differential...and the axles are the same thickness...you may be able to swap the differentials. Then you can keep the limited slip if you want to. If you tear them down at the same time...check it out and please let me know. :D Share this post Link to post Share on other sites
SAM58 34 #8 Posted July 31, 2011 It will be a direct swap, although you will notice a difference on hills from the Raider transmission to a C120. I did almost the same thing. I had a 1972 Raider 12, and replaced it with a 1977 model without the limited slip. It still worked really good, but i did notice that it would spin out a lot easier than the original Raider tranny. I sold the tractor but still have the old tranny, and I plan to do a complete rebuild someday. :woohoo: Share this post Link to post Share on other sites
Raider12 14 #9 Posted August 1, 2011 My plan was fresh'n up the doner trans with seals and anything else that looks questionable and to swap in a limited slip diff from another Raider 12. I have purchased just a limit slip diff a while back off Ebay. So this way I would end up with a trans that works just as it should in a Raider. I'll get some pice posted soon. Share this post Link to post Share on other sites
Raider12 14 #10 Posted August 1, 2011 Here are a few photos of the doner transaxle. The brake shaft is 3/4" diameter. The axles are 1 1/8 diameter as well. Does the bracket for the seat pan help ID what this came off of? I need to narrow this down so I order the correct seals bearings etc. One other question, is there a vendor best to use to buy these parts outside of Wheel Horse dealer? Thank guys, for the input. Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #11 Posted August 1, 2011 Looks like it could be a 103916 to me - which was used in the second and third generation C series tractors. (like the C-121 or C-165, etc.) The newer 110995 would be similar, but all of those I've seen had the end of the axle / wheel pilot / shifters painted black. (300/400/500 series) Share this post Link to post Share on other sites
Raider12 14 #12 Posted August 1, 2011 Thanks TT, I apprciate your expertise! Share this post Link to post Share on other sites
stevasaurus 23,816 #13 Posted August 2, 2011 I would listen to TT at this point...this is where I stop offering advise, and start to learn from him also. TT, I noticed that his trans has the brake drum located on the shaft that comes up from the cluster gear...instead of the 11-44T gear. I am sure we can give you a parts list for the bearings and seals. :woohoo: Share this post Link to post Share on other sites
Raider12 14 #14 Posted August 2, 2011 I am sure we can give you a parts list for the bearings and seals. I looked up the model of the trans here on Redsquare and then looked up the model of tractor it came in. I then went to Peachree and ordered the seals and a few known to go bad bearings. I think I good to go right now. But I may have to ask for help again. I have had these transmission apart before. But it has been at least 20 years ago. Share this post Link to post Share on other sites
stevasaurus 23,816 #15 Posted August 2, 2011 :D please let me know if you try to see if the differentials would swap. :woohoo: Share this post Link to post Share on other sites
Raider12 14 #16 Posted August 2, 2011 please let me know if you try to see if the differentials would swap. You bet. Im hoping to tear into this unit in the next night or two. I'll keep ya posted. Share this post Link to post Share on other sites
stevasaurus 23,816 #17 Posted August 2, 2011 Thanks... If you need anything...let me know. :woohoo: Share this post Link to post Share on other sites
