nylyon-(Admin) 7,427 #1 Posted November 8, 2007 How to install a 48" plow on your tractor, this assumes that the mower deck and mule drive are already removed. FIRST lay the plow on the ground in front of the tractor with the angle handle detached. SECOND roll the tractor over the plow until the engagement rod is just below the rear axle hitch. Be sure that while moving you move the angle handle out from under the tractor. Lift the rear of the plow into the hitch and lock it in. THIRD lower the lift handle and install the lift rod into the lift bar. Reattach the angle handle using some grease on the piviot points. That's all there is. I love how easy attachments are with these Horses... 6 Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #2 Posted January 7, 2008 I guess I cheat (or I'm just lazy ) when I put my blade on. I just run the right front tire up on the right side of the A frame (coming in from a slight left angle) and when the front tire gets to the angle lever, I cut the wheels hard left and then back to the right to go around it. (you can lay a block of wood in the space where the tire drops in to the gap in the A frame) That way I don't have to take the angle lever off. Sometimes I even do that with mower decks -- block it from moving and drive right up over the back of it. :D Share this post Link to post Share on other sites
zieg72 209 #3 Posted March 4, 2008 Any tips/ways to keep the rear from coming undone. A couple of times the rear on the right side came undone while plowing. Share this post Link to post Share on other sites
kj4kicks 154 #4 Posted March 4, 2008 Zieg, there should be a hole near each latch. After the blade is installed, put a cotter pin in each hole to keep it from loosening. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,539 #5 Posted March 4, 2008 Eldon, My rear attachment bracket does NOT have a hole on the lever. I thought about seeing if there was enough room to drill one, or maybe safety wire the lever or wire tie it. :thumbs: Share this post Link to post Share on other sites
KyBlue 655 #6 Posted May 12, 2008 How long is this bar?? between the blade and the lift arm I mean. Im sure its been brought up before, but I havent found the info ... My blade is missing this peice. I suppose I could make a J rod and use a trunion on one end.. thanks!!! Share this post Link to post Share on other sites
zieg72 209 #7 Posted May 12, 2008 4StarCstms said: How long is this bar?? between the blade and the lift arm I mean. Im sure its been brought up before, but I havent found the info ... My blade is missing this peice. I suppose I could make a J rod and use a trunion on one end.. thanks!!! Overall length is 5.25" with hole centers at 4". I just measured mine. 1 Share this post Link to post Share on other sites
KyBlue 655 #8 Posted May 12, 2008 Thats what I call a speedy response. Thanks a Bunch! Ive got to drive to grand Rapids Again tonite, so It'll have to wait till next weekend. Thanks again!! Share this post Link to post Share on other sites
AJ_Thanatos 516 #9 Posted August 22, 2014 On 5/12/2008 at 10:08 PM, zieg72 said: Overall length is 5.25" with hole centers at 4". I just measured mine. Are there cotter pins on the ends of those? Share this post Link to post Share on other sites
Tankman 3,520 #10 Posted October 15, 2016 There are two different lift links. 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,360 #11 Posted October 21, 2016 @Tankman When you use the long link do you also use the short link. I am a little confused. If not does the lift bar just flop around? Share this post Link to post Share on other sites
Tankman 3,520 #12 Posted October 21, 2016 On 10/21/2016 at 2:31 AM, elcamino/wheelhorse said: @Tankman When you use the long link do you also use the short link. I am a little confused. If not does the lift bar just flop around? Use both links to stop the flop. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,360 #13 Posted October 21, 2016 @Tankman that's what I thought , but when I tried using both links , I could not get the plow to lift at all. I need to go back and see if I have the links in the right holes. Most days I don't know up from down or left from right. Share this post Link to post Share on other sites
shallowwatersailor 3,214 #14 Posted October 21, 2016 On 10/21/2016 at 7:24 PM, elcamino/wheelhorse said: @Tankman that's what I thought , but when I tried using both links , I could not get the plow to lift at all. I need to go back and see if I have the links in the right holes. Most days I don't know up from down or left from right. No, you only use one link. If you are using the short link (picture #3), you use the liftbar which will allow the blade to float. The long link attaches to the bellcrank directly and allows pressure to be applied to the blade. Yes, the liftbar stays loose with this arrangement, or you can remove it temporarily along with the trunnion and chain. Share this post Link to post Share on other sites
cleat 6,906 #15 Posted October 21, 2016 On 10/21/2016 at 7:59 PM, shallowwatersailor said: Yes, the liftbar stays loose with this arrangement, or you can remove it temporarily along with the trunnion and chain. Or you can disconnect the trunnion and chain then tie them and the liftbar up out of the way if you are uncomfortable with removing it. (I personally would remove it to ensure nothing gets caught). 1 Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,539 #16 Posted October 22, 2016 While browsing the web yesterday for Wheel Horse videos, I ran across this one. I've seen this guy's videos before and from what I read, he's on MTF (and maybe here, don't know). He does have some interesting Wheel Horse videos on youtube. 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,360 #17 Posted October 22, 2016 Thanks for all the information guys it will be a big help. After the flu passes ( yes I got a flu shot on Tuesday AM and have been sick ever since) I will get my butt in gear and check out my hook up. I need it to push leaves not snow. Share this post Link to post Share on other sites
Big papi 9 #18 Posted November 19, 2017 Where a Can I get the rear mounting bracket for the rear axle? Share this post Link to post Share on other sites
rjg854 11,835 #19 Posted November 20, 2017 Check with AZ Tractor ,he's there in PA.. Share this post Link to post Share on other sites
Big papi 9 #20 Posted November 20, 2017 That’s just up the road in myerstown. Share this post Link to post Share on other sites
BOB ELLISON 2,981 #21 Posted November 20, 2017 Or you could go here and get new one. https://wheelhorsepartsandmore.com/brackets-linkages.html#!/Toro-Wheel-Horse-hitch-104659-SNOW-DOZER-BLADE-TILLER-BRACKET-WITH-SETUP-BAR/p/84954586/category=23566571 Share this post Link to post Share on other sites
Big papi 9 #22 Posted November 20, 2017 Just ordered one. Thank you all for the help. Share this post Link to post Share on other sites
squonk 42,223 #23 Posted November 24, 2017 I use a trunion and chain to lift the plow. I don't want to give the neighbor's all of my gravel! Share this post Link to post Share on other sites
pyroplegic 55 #24 Posted January 16, 2018 I use 3- 3/8" shackles, 1 on the plow where the pin of the shackle is in the hole & bell facing up, 1 on the lifter where the pin of the shackle is in the hole & bell facing down, and 1 connecting them together Share this post Link to post Share on other sites
12Horse Paladin 1,038 #25 Posted October 27, 2018 Tagging this, for future reference. I am sooooo slow with alla this; just now found....helps explain a lot! (I admit freely to doing so much better with pictures to use as reference....) Share this post Link to post Share on other sites
