massey 118 #1 Posted July 25, 2011 I have a hi/lo trans with 1 1/8th axles, 8 pinion, 3/4 brake shaft. Can anyone identify the model # for me? Thanks Ed Share this post Link to post Share on other sites
MikesRJ 552 #2 Posted July 25, 2011 Without pictures and a tractor it is installed on, probably not accurately. Is it on a tractor? If so, what is the tractor model number. If not, can you post a picture of the trans? Could be, I believe, a 5058, 5091, 103907, 103916, 103918 or other. Not completely sure about the 5058 though. This manual probably covers whichever one you actually have: http://www.mywheelhorse.com/graphics/file/...1958_-_1982.pdf Share this post Link to post Share on other sites
massey 118 #3 Posted July 25, 2011 Thanks Mike. The trans was in a 1968 Raider 9 which I thought would have made it a 5060 but when I went to put the seal on the brake shaft instead of a 1" shaft it is a 3/4" shaft. Here are some pics. Share this post Link to post Share on other sites
massey 118 #4 Posted July 25, 2011 After looking over the manuals, I think it's a post 1973 5091 due to the separate thrust washer under the reduction gear. Sound right? Did they have a 3/4" brake shaft? Share this post Link to post Share on other sites
MikesRJ 552 #5 Posted July 25, 2011 My info for a 1968 Raider 9 says model 5060 transmission. Service bulletin 252 indicates the limited slip differential could have been swapped for an 8-pinion diff. But the 5060 used a 1" brake shaft seal (p/n 1232, Seal - Oil 1" Shaft - Brake). This almost sounds like a 5091, which would make the correct seal part a SEAL-OIL : 100441 . I am going to defer to someone more knowledgeable on this model trans. You've reached the end of my ability to accurately help. Share this post Link to post Share on other sites
massey 118 #6 Posted July 25, 2011 Thanks Mike, I see in your chart 100441 is a 3/4" seal. I'll order them. Thanks for your time. http://www.brandywineits.com/graphics/file...ssReference.pdf Share this post Link to post Share on other sites
TT-(Moderator) 1,145 #7 Posted July 25, 2011 The thrust washer under the reduction gear on the pinion shaft indicates the newer two-piece pinion / reduction gear shaft assembly. Earlier models (5060, 5073, etc.) had a one-piece pinion / reduction gear shaft. The 5060 (and 5071, I think) had the brake drum mounted to the pinion shaft, which is why they call for a 1" oil seal. Newer versions had the countershaft-mounted brake drum. (like the one pictured above) The 103907 used the short plastic dipstick tube..... 71-08K801 is a '77 B-80 ~ which should get you to an IPL for that tranz. Share this post Link to post Share on other sites
MikesRJ 552 #8 Posted July 25, 2011 Thanks TT. Then building on TT's statements, the SEAL-OIL : 100441 would be the correct part you need. Share this post Link to post Share on other sites
massey 118 #9 Posted July 25, 2011 Thanks TT, it's definitely got the plastic dipstick tube. It's good to nail down what it actually is. I appreciate your help. Share this post Link to post Share on other sites
RStubbs100 0 #10 Posted July 25, 2011 HI to all, I am looking for a transmission (rear end) for my lovable old Wheeel Horse 1056. I looked in the manual and it says it has a 5053 tranny. I have not been able to find parts for it and would love for someone to contact me that may have a transmission or one that will fit. I dont know what all will fit it. Thanks, Russ Stubbs 4271 Carol Drive Reading, Michigan 49274 321 266 8775 Share this post Link to post Share on other sites
MikesRJ 552 #11 Posted July 25, 2011 HI to all, I am looking for a transmission (rear end) for my lovable old Wheeel Horse 1056. I looked in the manual and it says it has a 5053 tranny. I have not been able to find parts for it and would love for someone to contact me that may have a transmission or one that will fit. I dont know what all will fit it. Thanks, Russ Stubbs 4271 Carol Drive Reading, Michigan 49274 321 266 8775 Get a hold of RacinFool40. I believe Mike has several transmissions he's willing to part with. He will also know which will fit your machine. http://www.wheelhorseforum.com/index.php?showuser=2945 Share this post Link to post Share on other sites
racinfool40 202 #12 Posted July 25, 2011 Thanks Mike!!! But right now I have 2 completely rebuilt 10 pinion 8 spds and 1- 8 pinion 8 speeds..I will have a couple more 4 speeds in 2-3 weeks as soon as I can go pick them up!! Mr Stubbs what parts do you need for yours and yes the 1056 use's the 5053..Let use know what parts you need and I'm sure we can find them for you..MIKE.. :woohoo: Share this post Link to post Share on other sites
