redtin
DIFF BOLTS
redtin
Hi Horsemen
Any idea if there should be washers under the four diff bolts on a old C series box I have just boxed up and then thought oops should there have been, as it just had the locking nuts and looked as if it had never been down before I only have numbers on the box so unable to identify it's 1 1/8 axle
Thanks for any reply
Dan
daveoman1966
Schematics show a flat washer under the head of the bolt, but not on the nut end. You should also use Blue Loctite on threads / nuts...even with the nylok nuts. I've seen these separate before. I've also opened virgin diff cases with blue Loctite on threads. Just wipe off excess.
