Countdown To Christmas!
JUSS10
jerky gear engagement
JUSS10
So my 1054 is really jerky when going into gear. Cleaned all the pulleys, conditioned the belt, adjusted The brake, even tried it without the brake, still doing. Any ideas? New belt? New clutch spring? It's really bugging me....
Thanks
Justin
TT
:hide: Define, please.
Is the belt completely stopping when the clutch pedal is depressed for more than a few seconds?
JUSS10
The belt was dried out and cracking. I have this belt conditioner that you spray on the belt, it makes it more pliable like a new belt.
And yes the belt stops completely. I've set up clutches on all my round hoods with no problem...
TT
I read it exactly as it is typed and apparently I don't understand.
If the belt is stopped, this really doesn't make sense. :hide:
If it is grabby & jerky when you release the clutch pedal to go, then I'd say it needs a new belt.
JUSS10
sorry i posted this from my phone. the problem is that as i release the clutch in gear, it jerks until its moving. I guess i just wanted to verify that it seems like a new belt is needed as i went and cleaned all the pulleys. one other thing, and this may verify that the belt is out of round, but the tensioner "surges" or bounces up and down. thats why i thought maybe the spring wasn't strong enough or lost some tension over time.
once again, sorry for the confusion, i was trying to post from my phone.
Justin
Indy w h
I'd say replace the belt
Indy
chazm
Yep .. needs a new belt like the other guys suggest :hide:
Belt dressing is just a band-aid for worn belts
Chaz :WRS:
JUSS10
alright, so I read everyone saying "use genuine toro wheel horse belts" i know its a 82 inch long 1/2 wide. can i just order a 4L820 belt from napa and be done with it? or is it advised to spend more money (i would assume it would cost more) on a toro belt at my dealership?
Justin
chazm
I usually go to Tractor Supply or on line for my belts .
Toro will be more $$$ ... but then I'm a cheap azz :WRS:
Chaz :hide:
SAM58
It's The belt.... I have an old 1969 WorkHorse 700 doing the same thing.
:hide:
JUSS10
thanks guys, new belt will be ordered at napa on monday! thanks
can whlvr
the discussion of what belt is a very old one,i would get a toro belt,where i live its only 30 bucks,thats not alot of money to have the proper belt and as we know we need to keep the local toro guys in buisness for our wheelhorse parts,jmo
Martin
if anybody knows where we can get ahold of the oem belt (1592) that would be great. my dealer says nla.
JUSS10
well i plan to run to TSC today and pick up a kevlar belt. I'll let you know how that works. $17 isn't to bad especially when napa wanted $15 for just a regular run of the mill belt.
Justin
TT
If you really want to be a "purist", you can buy a 79-5980 belt from Toro. :WRS:
(#1592 was "replaced" by #114833, which was then "replaced" by #79-5980)
It's actually only 81.8" long, but that should be a benefit when used on worn pulleys. :hide:
Here's a cheaper one from Northern Tool.
JUSS10
hmm thats the same belt at TSC. to bad we dont have northern tools around where i am. I'll just run to TSC and get one. just pulled the old belt off and it has a few weird bumps in it and such, thinking that may have been the cause of the jumpy movement.
Martin
those bumps are probably from sitting and the belt has formed to the shape of the pullies. let me know how you go with whatever you choose. at the moment im planning on using a reasonable used oem belt until i come across something im happy with. ive used a few different ones on the starter gen and mower drive on the 875 and havent been overly impressed with aftermarket so far.
JUSS10
I'll let you know how it goes, i need to try something, this current belt is to hard to control and i dont want to be "dropping the clutch" all the time.
shorts
TORO :woohoo: bought/buys their belts from a major belt manufacturer with their numbers and logo on them, any major brand premium power belt should meet or exceed OEM :D specs and performance. the key operational phrase is "premium power belt" not to be confused with automotive or cheap aftermarket belts.
JUSS10
well got the new belt on today, wow what a difference. i picked up one of those blue PIX belts from TSC. i think the 82" was $17. well worth the money spent. it is a very smooth transition now from a stand still into gear. the old belt was very stretched out and i think that was primarily the issue. mowed the lawn tonight and it worked great.
Martin
thanks for the info, justin.
JUSS10
glad you got it, i was going to post it in your build thread. i think the only thing now is the brake drum needs to be cleaned. then it should be great!
