jasoncracer
Hydro.help
jasoncracer
My c141 had atf when I purchased it. Should I let it be works fine or change it to oil?
bigd
let it be.mine works fine on atf.my cousins c161 runs fine with oil.
horse junkie
If you want to change it use dexron III, this is what mt dealer told me has been in my 1276 for years with no problem.
shorts
be careful with ATF some of them have friction addatives(grit) to improve clutch pack performance in automatic transmissions, hydrostats are straight hydraulic drive pump/motor units and friction improvers are detrimental as they can promote premature wear :D :woohoo:
