Tee
14 horse
Tee
can a 14 horse kohler be swapped with an 8 horse on a b80. i`m thinkin it will. thoughs pleasee.
Jim_M
Yup, it can be done.
SousaKerry
remove the engine mounting bracket and bolt directly to the frame. You will need the correct oil pan and the PTO setup from a 10HP or larger tractor to make it work properly, the 8hp motors have a smaller drive shaft and used a smaller pto setup (this is unless your 14 came from a Johnny Smear then the shaft size is the same)
jonsteffen
ok
Sousakerry2 what holes do u use to mount the bigger kohler i and going to be useing a narrow base block i have the oil pan for it
SousaKerry
Whichever 4 holes fit. it may help to put the belt guard on the tractor and bolt it to the motor to get the engine in the right spot
