Tee 0 #1 Posted June 22, 2011 can a 14 horse kohler be swapped with an 8 horse on a b80. i`m thinkin it will. thoughs pleasee. Share this post Link to post Share on other sites
Jim_M 179 #2 Posted June 23, 2011 Yup, it can be done. Share this post Link to post Share on other sites
SousaKerry 502 #3 Posted June 27, 2011 remove the engine mounting bracket and bolt directly to the frame. You will need the correct oil pan and the PTO setup from a 10HP or larger tractor to make it work properly, the 8hp motors have a smaller drive shaft and used a smaller pto setup (this is unless your 14 came from a Johnny Smear then the shaft size is the same) Share this post Link to post Share on other sites
jonsteffen 6 #4 Posted August 28, 2012 ok Sousakerry2 what holes do u use to mount the bigger kohler i and going to be useing a narrow base block i have the oil pan for it Share this post Link to post Share on other sites
SousaKerry 502 #5 Posted August 28, 2012 Whichever 4 holes fit. it may help to put the belt guard on the tractor and bolt it to the motor to get the engine in the right spot Share this post Link to post Share on other sites
