jus97tin
Transaxle leaking
jus97tin
My 1967 1077 wheel a matic is leaking bad out if the rear end. I had the pump gear drive off of the side bacause I thought that i had to replace an inner bearing. Turns out I didn't have to so I put it back together but the gasket/seal that went between the axle housing anf the pump riped on the bottom. i trying to used a gasket sealer and reuse the old gasket and it worked of a while but then it started to leak out all over the garage floor. I apears that the do not reproduce the gasket that i need so what is the best fix for this. The tractor does move with no problems other that the fact that it not doesn't hold the rear end fluid.
rmaynard
I don't know how intricate the gasket is, but you can buy gasket material at most auto parts stores and try making a new one.
can whlvr
i did as bob said on my c160,i took my time and used a very sharp xacto knife and it turned out fine
