BairleaFarm
kohler knock
BairleaFarm
If a 8hp kohler had a knock what would be knocking? Kinda a confucing question maybe.
KyBlue
Connecting rod possibly . .. probably ... maybe?? If your thinking rebuild.. gotta dealer up in Cinci who'll do a rebuild for 200 ..
Rollerman
Could be a lot of things...like the connecting rod at the crank...the wrist pin...or piston slap in a worn bore.
If it's knocking...be a good idea to have a look inside & see just what is causing it.
BairleaFarm
Whats a complete rebuild kit cost? how about just a gasket kit?
KyBlue
You could go down to scotts and ask em. I've not priced the parts. When I rebuild mine, probably this winter, Im just gonna let the shop in cinci do it
oldandred
just a gasket set want stop a knok you need to take to some that knows what there doing there easy to build but if youre never do it well you can spend money for nothing
good luck
BairleaFarm
I know it wont stop the knock but there may be nothing wrong and i dont reuse old gaskets.
