WH Raider10
Transmission
WH Raider10
Hi guys,
The seals on both sides of my 312-8 are leaking a bit and the hubs on my raider 10 4 speed tranny are not perfect in place anymore. I will need a hub puller to fix this problems. I've tried different pullers but non of the ones I've work. Can someone give me the size of the pulley puller I need to get the hubs of? My friend in the States can ship me one to belgium.
Thanks,
Pieter-Jan
wheel-mule
One is very easy to make.Just get a piece of 1/2 or thicker flat stock.Drill a 3 bolt or 5 bolt pattern and put a 3/4 inch bolt in the center.Bolt the flat stock to the hub and use the center bolt to pull the hub off.
