WH Raider10 17 #1 Posted June 11, 2011 Hi guys, The seals on both sides of my 312-8 are leaking a bit and the hubs on my raider 10 4 speed tranny are not perfect in place anymore. I will need a hub puller to fix this problems. I've tried different pullers but non of the ones I've work. Can someone give me the size of the pulley puller I need to get the hubs of? My friend in the States can ship me one to belgium. Thanks, Pieter-Jan Share this post Link to post Share on other sites
wheel-mule 46 #2 Posted June 11, 2011 One is very easy to make.Just get a piece of 1/2 or thicker flat stock.Drill a 3 bolt or 5 bolt pattern and put a 3/4 inch bolt in the center.Bolt the flat stock to the hub and use the center bolt to pull the hub off. Share this post Link to post Share on other sites
