skrusins
Jerking Hydro?
skrusins
I never owned a WH with a hydro, and not sure what to expect.
I have a Kubota zero turn and when going from forward to reverse
it doesn't jerk or jump, it really does tear up the grass though.
I'm hoping that it's me, but when I mow with my WH if I shift from
foward to reverse it make a stop. Then when I shift forward it to
lunge or buck. When I go down hill it wants to go fast and I have to
pull back on the lever. Going uphill I have to keep the lever up to
make it up.
I been reading and enjoying your site, very informative and great group
of members. I notice that there is and alot of members that have hydros.
I hope I'm doing something wrong and get some help, or is this common.
Thanks in advance
can whlvr
:hide: my hydro does not lunge forward unless i push the lever too fast forward,but if you use smooth action it is smooth,and yes the hydros wander down hill,and i have to give her more lever going uphill
skrusins
Thanks Don, The wandering up and down information helps
me alot. I do feel like I use a smooth action, but maybe not
smooth enough. Thanks reply really helps.
rick
My 416H speeds up going downhill, and slows going uphill. It will jerk when the lever is moved rapidly, due to the "dynamic braking" feature built in to the Eaton 1100 hydro. I have learned a soft touch alleviates the jerking when moving the stick. I can slide the tires easily on the smooth concrete floor when rapidly slowing down from full speed.
skrusins
Thanks Rick, That is good helpful information. At least is isn't me.
I originally thought I had something adjusted wrong, and didn't
know what to expect. You and Don good help. Thanks
