persof 14 #1 Posted June 6, 2011 I have a C161a that i am restoring (not for show but mechanically sound for work). The right hand axle leaks and it is worn where a previous owner left the hub set screws very loose. It is not critical that I do this but unless this is scarry I want it right. How hard is it to replace the axel and the seal? When the transaxle comes appart do springs and things "pop" out? Thanks Francis Share this post Link to post Share on other sites
daveoman1966 3,797 #2 Posted June 6, 2011 There really aren't very many parts inside the transaxle. You can download a manual for it. If you need to replace the axle, I have that....as well as many other parts including the differential and other gears. CAUTION... when you take the Sundstrand power unit off of the transaxle, KEEP IT CLEAN. Just a little bit of dirt/grime will lead to a hydro pump rebuild. Also...thoroughly flush all dirt and debris out of the transaxle before reassembly. Share this post Link to post Share on other sites
persof 14 #3 Posted June 7, 2011 Daveoman, Does the Sunstrand unit have to be removed from the transaxle? The manual that I downloaded only showed the Sundstrand unit, which manual do I need for the transaxle itself? Looks like four bolts to remove the transaxle unit from the tractor. How tricky is it to re-attach the "go" lever assy? Thanks Francis Share this post Link to post Share on other sites
