byoung 0 #1 Posted May 26, 2011 I have four 1 1/8 8 speed transaxle how do I identifi witch ones are 8 pinion without breaking the case apart. Thanks Brian Share this post Link to post Share on other sites
byoung 0 #2 Posted May 26, 2011 Never mind I answered my own ?. I done some reading on some of the other post and had an idea. I took the dip stick tube out of the transaxle and used a flash light to shine down in the transaxle I was able to see 4 bolt heads and 8 pinions on the 8 pinion transaxle and you will see 5 bolt heads and 5 pinion on a 10 pinion transaxle. Hopes this helps someone else. :hide: Share this post Link to post Share on other sites
stevasaurus 23,045 #3 Posted May 26, 2011 That is very good to know. :hide: Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #4 Posted May 26, 2011 As long as the cylindrical spring is not broken or missing, the axles on a 10 pinion will both rotate in the same direction, while the 4 & 8 pinion units will rotate in opposite directions. Share this post Link to post Share on other sites
