Retired Wrencher 5,648 #26 Posted May 29, 2011 truckin 88 your motor is a 1976 Wrong. As I previously stated - the serial number on Will's engine is only 6 digits - which is early 1965 & older. 1969 thru 1979 used the 7 digit serial numbers. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ I have received a few serial numbers so far and only have one that's out of line with my initial interpretation. (Denny Clarke's 701 engine) I can still use some more numbers if anyone is willing to send them. They must be from a verified original application. (401, 702, 633, etc.) Terry so the picture that I sent to you is a 1965??? or not Gary B..... I believe this is the original engine in this tractor. Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #27 Posted May 29, 2011 Terry so the picture that I sent to you is a 1965??? or not Gary B..... I believe this is the original engine in this tractor. If you're talking about the picture you posted a few posts back, the answer is there's no way to accurately know unless you owned it since the day it was new. To start with, a 1965 engine should have a metal ID tag riveted to the side of the blower housing, not ID decals. Could the blower housing have been changed and not the engine????? I don't know. There are no date codes on the blocks, so your guess is as good as mine. I do know (for sure) that the ID decal is not original - but that's all I'll admit to. The serial number 4091293 is seven digits - used from 1969 to 1979. That is public printed information contained in the Kohler service manual "TP-2379" / page 1.3 / figure 1-2 Seven digit serial numbers starting with 40 to 49 denote 1972. If you want the correct ID tag, RS member Perry currently has 1075 engine tins listed on eBay. There isn't much time left on the listing, so you better be quick. :hide: Share this post Link to post Share on other sites
motofast 0 #28 Posted May 30, 2011 the letter a b c d e stand for 1965 thru 1969. also its possible that you could have a 1969 with a letter and a seven digit number, listed both ways might be letters are early 69 and digits are later 69. also TT you say i was wrong but truckin posted his serial # 750423 that would make it a 1976! Share this post Link to post Share on other sites
Retired Wrencher 5,648 #29 Posted May 30, 2011 :hide: Hi Terry I did some research today and I came up with this. The engine is a discontinued model = the D at the the end of the S/N. STK 4 = slow moving stock. And this info came out of the pricing book for Kohlers. So it is a mini block # B-237869 and short block # is c-235618. so i think this puts to rest the Mystery?? Gary B.... Share this post Link to post Share on other sites
Retired Wrencher 5,648 #30 Posted May 30, 2011 this is from the pricing list.. with the #`s Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #31 Posted May 30, 2011 TT you say i was wrong but truckin posted his serial # 750423 that would make it a 1976! You're still wrong. Exactly how do you get seven digits out of 7 5 0 4 2 3 ? I'm not even sure if K-141 engines were still in production in 1976. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ @Gary: I'm not following where you're going with short & miniblock numbers. I'd feel safe to say that every K series engine manufactured by Kohler had a specific service engine, a miniblock and a shortblock. (for replacement / repair purposes) The numbers on the sticker on your engine are for a 1972 "basic" K241 with a special oil sump. This is what I make of it: it means the original engine on your 1075 was replaced with this one in 1972/73. If you want it to appear correct, buy the tins from Perry and install the blower housing on your current engine - or at least install the ID tag on your current blower housing. Share this post Link to post Share on other sites
motofast 0 #32 Posted May 30, 2011 sorry about the seven digit thing, what i meant to say was the first two digits of that # 750423 is what you use. so in the 73 to 79 catogory 750423 would be 1976. Share this post Link to post Share on other sites
racinfool40 202 #33 Posted May 30, 2011 As Stated in the Kohler Manual! you need 7 digits to date a kohler engine from 1969 to 1979 and 8 digits from 1980 to 1985 and 10 digits from 1985 to 1995.. so dating a 6 digit serial # doesn't apply unless A-1965 B-1966 C-1967 D-1968 E-1969 So dating pre 1965 kohlers is an educated guess.. As TT stated we are going by what #'s Have been provided or are known from Tractors with origional engine's these #'s and digit have been taken right out of the kohler engine manual!! Page 5 Motofast you would be correct if it was a seven digit # but were dealing with a 6 digit #.. Share this post Link to post Share on other sites
motofast 0 #34 Posted May 30, 2011 my info is from a page out of a kohler manual for warranty work if you were a dealer. and you are correct. you have to have seven digits! it takes old people longer to figure things out! Share this post Link to post Share on other sites
Retired Wrencher 5,648 #35 Posted May 30, 2011 so they made these to look like a stater/Gen in the 70`s??? engine.I got the #`s from the speck #`s and went into price catalog insert from that dealer manual you just cross reference the #`s ether way we know now it is not the original motor in it Bummer as for the tins someday I will get around to it. thanks and T/Care Gary B............ Share this post Link to post Share on other sites
blsjr@comcast.net 0 #36 Posted June 27, 2020 Wheel Horse Suburban/plow as mine is a T 4 HP serial # 433597 model # 313884 I believe it to be 1960-61 Share this post Link to post Share on other sites
AMC RULES 37,146 #37 Posted June 27, 2020 (edited) 2011, WOW! Talk about pulling a thread out of obscurity! Edited June 27, 2020 by AMC RULES Share this post Link to post Share on other sites
953 nut 57,904 #38 Posted June 28, 2020 3 hours ago, blsjr@comcast.net said: Wheel Horse Suburban/plow as mine is a T 4 HP serial # 433597 model # 313884 I believe it to be 1960-61 If you want to date an engine there may be social media site devoted to that. If you want to know when the engine was built this thread may help. 1 Share this post Link to post Share on other sites
RandyLittrell 3,894 #39 Posted June 28, 2020 @blsjr@comcast.net Why don't you start a thread about your tractor and include some pics! We love pics! Randy Share this post Link to post Share on other sites
R Scheer 505 #40 Posted June 29, 2020 And here I thought someone was looking to date an old Kohler engineer... 2 Share this post Link to post Share on other sites
