Toejam
Tire/rim Question
Toejam
My 310 caught a flat on the rear today. I am using it to mow. I will not be able to repair it for a couple weeks. My question is, Can I put the rims and tires off the 633 or the 1055 on just to get by for a few weeks?
Thanks
RT
Jim_M
Depends on what size tires everything has. It doesn't take long to try it and find out.
Toejam
Width is the issue....will that be a problem?
Thanks
RT
can whlvr
i wouldnt think width should be an issue,unless the center of the rim where the axle goes is wider on a 1054 or633,like said give her a try,nothing too loose
Toejam
Thankyou, I'll give it a try today.
Toejam
Yep, They work just fine...thanks for your input.
