Electro12WH 50 #1 Posted April 30, 2011 Does anyone else besides me not know that an 8 speed trans won't fit in a '74 B80? I went to all the work to put a 8 sp trans from a C160 in my B and found that the hi-lo shifter hits on the floor of the tool box/seat base. I know that the '74 B is about 2" shorter than a standard horse. Now I know where that 2" is missing. Share this post Link to post Share on other sites
Kelly 1,030 #2 Posted May 1, 2011 they are shorter in the nose of the tractor, you may just need a diff. high low shift handle, post a pic of the issue. Share this post Link to post Share on other sites
Electro12WH 50 #3 Posted May 1, 2011 I can't post pics w/ my setup. The small post where the hi-lo- shifter emerges out the top of the trans hits the bottom of the tool box. A couple inches farther forward and it would have come through the opening where the gearshifter rises through. Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #4 Posted May 1, 2011 You have to drill a hole in the "toolbox" bottom for the hi-lo shift fork shaft / shifter. Share this post Link to post Share on other sites
sorekiwi 761 #5 Posted May 1, 2011 Here is Stephens step by step tutorial: http://www.wheelhorseforum.com/index.php?...14302&hl=ranger and one of his photo's: Share this post Link to post Share on other sites
Electro12WH 50 #6 Posted May 2, 2011 False alarm! I was being a stupid! After staring at it a long time and taking measurements, I realized that it had to go. The 4 speed shifter isn't a problem, but the hi-lo is a pain and I couldn't find a set screw to remove it. Anyway the trans is in and my new, improved B80 is up and running. Share this post Link to post Share on other sites
Electro12WH 50 #8 Posted May 4, 2011 I'm not equipped to post pics on this forum. It's a typical faded old WH that I bought at an auction for $75. The engine runs well and the 8 speed is a real plus. I have a snowblower for it and a snow blade. Now I'm fixing up a 36"RD mower deck. Also I'm going to rewire and install a headlight. Share this post Link to post Share on other sites
