galaxiejoe
856 wiring help
galaxiejoe
Just a quick question, where does the starter solenoid mount on the tractor? Currently mine just lays on the battery and I want to fix that, dose anyone have a few pictures where it should be? Also what is the best way to run the gas line from the tank, on the left or right side?
Joe
Kelly
They did not use a solenoid originally, the key switch transferred power to the starter, yours probably has a newer ign. switch, and can not handle the load of cranking the engine, so a solenoid was added, you will have to find a place that looks good and mount it.
Save Old Iron
Anywhere that allows easy access to the battery and starter terminals would be fine.
If the solenoid is a 3 terminal configuration, attach it to any grounded part of the tractor.
The fact it is now "just laying on the battery" makes me believe it may be a 4 terminal with a separate ground wire attached. If it is 4 terminal, just make sure the ground wire from the solenoid is attached to a good ground.
