dmoore 942 #1 Posted April 13, 2011 Since I wasn't raised up around the Wheel Horse tractor can someone explain the difference between the snow & dozer blades, if there is one? Thanks! :thumbs: Share this post Link to post Share on other sites
mr.pipes 4 #2 Posted April 13, 2011 They are the same thing. Where I am from they are called snow plows or plows. But plows can be confused for a garden or moldboard plow. Share this post Link to post Share on other sites
Kelly 1,030 #3 Posted April 13, 2011 Yes the front blades can be called both, but there are different styles of the snow/dozer blade to fit the diff. years and models of tractors, the one that fit's your tractor is the most common, and MANY years will fit. Share this post Link to post Share on other sites
dmoore 942 #4 Posted April 18, 2011 That's what I thought.......now if a nice one would pop up for sale.......... :thumbs: Share this post Link to post Share on other sites
can whlvr 993 #5 Posted April 18, 2011 check the want adds,theres usually lots of them around,i have a friend that lives in your neck of the woods,leesburg,not too close to the ocean but somewhere near you,and no shes not into wheelhorses,just horses Share this post Link to post Share on other sites
dmoore 942 #6 Posted April 19, 2011 Don, I'm kinda picky so I would have to have a nice restored one..no time to restore one! And we have lots of horses (4 legged) here on the Eastern Shore..... :thumbs: Share this post Link to post Share on other sites
C-160 Tractor 1 #7 Posted April 19, 2011 Yes the front blades can be called both, but there are different styles of the snow/dozer blade to fit the diff. years and models of tractors, the one that fit's your tractor is the most common, and MANY years will fit. what are the differences in the styles? I am currently looking for one as well for my C160. I am looking for it to move some dirt around. Also I saw some video's on youtube with people with hydro lift they can really put the down force on the blade to scrape. I have a manual so no hydro, will it still be able to scrape dirt around as well? thanks Share this post Link to post Share on other sites
mr.pipes 4 #8 Posted April 20, 2011 what are the differences in the styles? I am currently looking for one as well for my C160. I am looking for it to move some dirt around. Also I saw some video's on youtube with people with hydro lift they can really put the down force on the blade to scrape. I have a manual so no hydro, will it still be able to scrape dirt around as well? thanks Here is a link with info on all the different plows. http://www.wheelhorseforum.com/index.php?showtopic=541 Here are a couple links about the solid link used to apply down pressure. http://www.wheelhorseforum.com/index.php?showtopic=5067 http://www.wheelhorseforum.com/index.php?showtopic=1187 Share this post Link to post Share on other sites
can whlvr 993 #9 Posted April 22, 2011 yes with the solid link and my c160 auto i can put the front end in the air wheels off the ground Share this post Link to post Share on other sites
dsm382 0 #10 Posted April 25, 2011 Also I saw some video's on youtube with people with hydro lift they can really put the down force on the blade to scrape. I have a manual so no hydro, will it still be able to scrape dirt around as well? thanks why yes, yes you can scrap dirt no problem, might take a pass or two but my little B-80 manual don't mind a bit. although now the dang lift handle keeps falling out, need to find out how to fix that, but it does still work. it took a few passes to get the gravel gone, but was able to start digging in the dirt with no problem. i also leveled a bunch of ruts in the back yard with it, just put a bit of weight on the blade, made it harder to lift but it helped. there was a much larger rise in the drive before i started Share this post Link to post Share on other sites
