mark89 0 #1 Posted April 7, 2011 I have a 62 lawn ranger with a 3 speed trans. I am looking for a how to on changing out the axle seals an brake seal. also is there any thing elce i need to do to the trans be be for i put it in paint also what type of oil do i use for it. any help would be grate thatnks Share this post Link to post Share on other sites
littleredrider 409 #2 Posted April 8, 2011 Dunno bout the seal, but I used 80/90 in mine. Share this post Link to post Share on other sites
rmaynard 15,891 #3 Posted April 8, 2011 All three of your seals should be the same size, 1". Toro part number #1232. Remove both hubs and the brake drum. Pry the seals out with a small screwdriver, ice pick or hook. Clean the axles well, removing any burrs from the keyways. Lubricate the axles and inside of seal, and insert the seal fully. Be careful not to damage the seal by driving it in with anything hard or sharp. Same basic procedure for the brake shaft. Hope this helps. Search the forum. You will find many more explanations for seal replacement. Share this post Link to post Share on other sites
mark89 0 #4 Posted April 8, 2011 thanks that was quick an u awnserd my next ? about the part number. alost where can i get a new shifter boot Share this post Link to post Share on other sites
Kelly 1,030 #5 Posted April 8, 2011 I would change the input seal also, behind the drive pulley, while your at it, as for the shifter boot, get one from a local Toro dealer, they run about $5 Share this post Link to post Share on other sites
mark89 0 #6 Posted April 8, 2011 ya i mite as well is it the same size seal as the outher 3 Share this post Link to post Share on other sites
rmaynard 15,891 #7 Posted April 8, 2011 Nope. It's a #1303. Share this post Link to post Share on other sites
rmaynard 15,891 #8 Posted April 8, 2011 Edit: The 1303 has been replaced by a #100441 Share this post Link to post Share on other sites
mark89 0 #9 Posted April 8, 2011 bob the last 2 numbers u sent is on the seal an one the boot number Share this post Link to post Share on other sites
rmaynard 15,891 #10 Posted April 8, 2011 Somehow I duplicated my posting, so I edited it and put the new seal number. The number for the boot is 3577. Share this post Link to post Share on other sites
