lobo 22 #1 Posted April 6, 2011 :wh: May sound funny but I was wondering if anyone knows where I can get a rebuild kit for my lift cylinder on my C-161 auto without giving up my first born or any appendages? :thumbs: Share this post Link to post Share on other sites
smoreau 658 #2 Posted April 6, 2011 Me too! I would like a rebuild kit for my electro 12 Share this post Link to post Share on other sites
Kelly 1,030 #3 Posted April 6, 2011 First are the the style you can take apart? some are welded together, they can be cut open and rebuilt then welded back together, take it to a hyd. repair shop see how much they want to rebuild it, I did the one for my round hood this winter, it come right apart not welded, and cost about $5 for the seals from a local hyd. repair shop. Share this post Link to post Share on other sites
Trouty56 567 #4 Posted April 6, 2011 I asked one of the maintenance guys at work to cut a welded one open and try to fix it. He got it apart and bought the seals at McMaster.com. They are just regular hydraulic seals. It took him 3 tries to get it right. First time it looked good but leaked. When he reopened it he said he rolled the pressure seal. Second time he melted the seals cause he messed up the weld. Third time was a charm. Got the weld right and cooled it in some water in time. :thumbs: Share this post Link to post Share on other sites
KB9LOR 4 #5 Posted April 7, 2011 One of our members here has the seals for rebuilding the lift cylinders, PM indywh....he is our resident Hyd Lift guy. Share this post Link to post Share on other sites
lobo 22 #6 Posted April 7, 2011 :thumbs: A big thank you is in order, thought that someone would have some idea. Since I've been a member I have went through all the past posts and have gotten alot of useful information, thank you all very much. :wh: Share this post Link to post Share on other sites
lobo 22 #7 Posted April 16, 2011 Sorry, been tring to figure out how to post pics. If this works, after removing the lift cyl., remove the snap ring, if it's one you don't have to cut open, next, pull rod all the way out, I used my vice to hold it and tap lightly on the cyl. to remove the piston You now have it apart Now remove the retaining nut and seperate the pistons and remove the O-rings With a small, I used a screwdriver, tool (pick, alan wrench, etc.) remove the wiper seal in the end of top piston Replace all the above with new and reverse order to re-assemble. Hope this helps someone 1 Share this post Link to post Share on other sites
Trouty56 567 #8 Posted April 16, 2011 Nice tutorial Lobo!! :thumbs: Share this post Link to post Share on other sites
Kelly 1,030 #9 Posted April 16, 2011 Nice job, glad to see it was rebuildable, but is that one more O ring on the shaft right below the threads?? 1 Share this post Link to post Share on other sites
lobo 22 #10 Posted April 16, 2011 Well what do you know, thanks Kelly for pointing that out, not sure, raining out now, will surely look tomorrow. Share this post Link to post Share on other sites
earlleecliffton 38 #11 Posted April 16, 2011 Where did u get the o rings andthat rubber seal on the end? Share this post Link to post Share on other sites
lobo 22 #12 Posted April 16, 2011 Thanks Bob, and yes Kelly that is another O-ring just below the threads. I haven't got the O-rings or seal as of yet, going to try the hydraulics shop. Something tells me that you've done this before, Kelly? :wh: Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #13 Posted April 16, 2011 Unless things have changed in the last 5 or 8 years, that cylinder should take the OEM seal kit #101699, which is around $45 to $50 Share this post Link to post Share on other sites
lobo 22 #14 Posted April 16, 2011 Thanks TT, yes it list for $47 and change but am trying to get around that Share this post Link to post Share on other sites
lobo 22 #15 Posted April 19, 2011 Just an update on the seals, just got back from the hydraulics shop, got everything I needed for less than $8. Got it all back together now to get it swapped out, oh yeah, also got the o-rings that go on the hoses too. :thumbs: Share this post Link to post Share on other sites
WH854 44 #16 Posted April 20, 2011 :wh: That is good to know Chas :D Share this post Link to post Share on other sites
Kelly 1,030 #17 Posted April 20, 2011 Like I said I rebuilt mine for around $5 but the old ones don't have as many seals, most of the stuff is common hyd. seals. Share this post Link to post Share on other sites
stevasaurus 23,063 #18 Posted April 21, 2011 Excellent thread Lobo...should help many members...thanks for sharing. :thumbs: Share this post Link to post Share on other sites
Charbs152 254 #19 Posted December 19, 2020 (edited) Edit, figured out my own question Edited December 19, 2020 by Charbs152 1 Share this post Link to post Share on other sites
JohnD 145 #20 Posted December 20, 2020 I love to see these nine year old threads still popping up as relevant. Share this post Link to post Share on other sites
rick 245 #21 Posted December 29, 2020 ^^^^I like to see the older posts too. We aren't all charter members, lol! Share this post Link to post Share on other sites
