mark89
resto of my horse
mark89
well weathers starting to warm up so i figgered i sould get started on my lawn ranger. Befor i try to take the decal with the vin off i need to know if it can be re made. Or do i have to try an salvage it cas its kind of pelling prety good. Aslo would it be best to have my tins sand blasted of hand sand them.
Kelly
The decal can be reproduced with the correct serial no, see, our vendors section, as for the metal, I like sand blasting, I've been doing body work for 25+ years and we have always sand blasted stuff.
sorekiwi
Terry (Vinylguy) will do a beautiful reproducion of your serial plate.
My original:
Terry's reproduction:
I preserved the original in a little baggy for some reason. You can usually work them off with a razorblade.
If you dont want to sandblast, or pay someone else to do it, have a read up on electrolysis tanks.
Toejam
Do you have a hood for this project? This might inspire me to do a restore.... :thumbs:
mark89
yes i do have a hood for it i finshed braking it down today can do more sadly have to work nites for the week
mark89
well have been making some head way. dorped the frame tower rims an some outher parts off to be sand blasted. I orderd new front tires an i am gonna reuse the rears i cleand them up they look nice. also i drained the rear oil looked good an refilled it then wire weeled the whole thing just waiting on my shifter boot an seals. have some pics i willl up load tonite
mark89
got some pics of the progress later then i said
parts form blaster
tranny all cleaned up an new oil also wating on seals an boot
scrobed the tires down gonna try to reuse them
painted a few parts i cleaned
also what do u guys think i should do with this the brass sleves are groved an warn are they factry or they made to sit the larger rims
mark89
havent had a ton of time to work on it cas of work with going form nites to day to nites lol heres what i have gotten done
>/i40.photobucket.com/albums/e204/beefy777/DSC00101.jpg
Horse'n Around
Hey thats really looking terrific! Keep up the good work.
VinsRJ
Looking good! :thumbs:
Coadster32
Looks good! Keep up the good work. :thumbs:
Toejam
Very nice...keep up the good work... :thumbs:
HankB
I'm replying mostly to see what the other two pictures look like :thumbs:
I wonder about the brass bushing... Is it supposed to be part of the wheel that got stuck to the spindle?
mark89
the bass bushiings were made as a sleve to thiken an lenghen the axel they were sliped over an drilled an held in place with a roll pin the wheel was kept on with a thin brass washer an a snap ring
mark89
havent had time to update made new axel sleves out of miled steel an put grease groves in them also got most of the sheet matel body work done an ready for primer working on the hood now an the gas tank up thast still in dabate to polish it out or paint it
jusjeepn
Mark, I just found this thread and have been looking at your progress. It's looking great so far! I did want to point out that your front wheels are not original to the tractor. That is why the spindle was so worn. If you'll look at these pictues, you'll see the original style which has bearings. They are probably a bit smaller than the ones you have but the bearings will save your spindles and your rims! Also notice the rear wheels. Either your transmission has been changed to a later model transmission and 12" wheels bolted on or someone added rear hubs and the 12" wheels. It originally came with 8" wheels on the back and 4" on the front.
Kelly
It kinda looks to me that they put the rear wheels on the front, the rearend should not have hubs, the rims fit right on the axle shafts.
jusjeepn
I think you're right Kelly! I went back and looked at the tires that were mounted on the front and sure enough they look just like the factory rear tread for the 33/34 Ranger!
