Irv
Removing 8-speed
Irv
Ok guys, need some help here. Trying to take the transmission out of my c-100. The manual says to remove right foot rest, belt guard, brake rod and unbolt the tranny. Then rotate trans. so shift levers clear. This is where I'm stuck, can't seem to get the hi/lo lever to clear the shaft for the brake. Any tips? :thumbs: thanks in advance.
dgjks6
I just went through this while reinstalling an 8 speed trans. I ended up putting the hi/lo lever on after I put the transmission on.
Irv
At this point I don't even want to think about putting it back in. Looking for help guys!
rmaynard
You may find that you have to remove the bell crank assembly to get the transmission out. That's not difficult. It's easier than trying to get the roll pin out of the hi/lo shifter handle.
Irv
Thanks Bob, I've been looking at that and trying to figure out how to get it out.
Irv
Took out the bell crank-simple like you said Bob. thanks much for your help.
