redtin 0 #1 Posted March 27, 2011 Hi My 416-8 and my spare tran both are hard to engage 2nd and 3rd will engage but most times it need some force any idea is it major work. Dan Share this post Link to post Share on other sites
mavfreak 11 #2 Posted March 27, 2011 Is it just when the engine is running or is it when its just sitting there or both? Share this post Link to post Share on other sites
redtin 0 #3 Posted March 27, 2011 Thanks for reply it's both Share this post Link to post Share on other sites
mavfreak 11 #4 Posted March 27, 2011 Not real sure but sounds like it could be a bent fork. Share this post Link to post Share on other sites
redtin 0 #5 Posted March 27, 2011 Is this a common problem Share this post Link to post Share on other sites
mavfreak 11 #6 Posted March 27, 2011 there is some problems with shifting forks but if that is the problem it is fixable. I have seen were they can be bent or worn. There is others here who have alot more experience than I. I'm sure they'll be chiming in on this soon. But I feel thats is were you'll be going Share this post Link to post Share on other sites
dgjks6 6 #7 Posted March 27, 2011 Somethimes this happens when the gears are not aligned. You should never need to force it. I would first check the fluid, then make sure the clutch is working properly. I would check to see if its the same in first and reverse. If it is having a hard time between gears, release the clutch and depress it again and try the gears. If that is still the case I would consider opening the transmission. Share this post Link to post Share on other sites
stevasaurus 23,041 #8 Posted March 27, 2011 It is possible your shifter is not right...before you drop the trans, pull the shifter out and inspect the end and the pivot. When you put it back in...snug up the set screw, then back off about 1/2 turn and tighten the lock nut. If it is in the trans, make sure you pull the shifter back out before you try to separate the trans halves. Like was stated...could be a bent fork. Could also be a bad or worn detente ball. A 1/4" ball bearing that keeps the shifter in place after you shift gears. read this thread about adjusting the shifter... http://www.wheelhorseforum.com/index.php?showtopic=15678 Share this post Link to post Share on other sites
redtin 0 #9 Posted March 27, 2011 Thanks for the replies It strange as I just obtained a second transmission for this reason but it is the same I mean when they are stationary and when running hard to engage 2nd & 3rd oil level is correct. Share this post Link to post Share on other sites
redtin 0 #10 Posted March 29, 2011 Have now opend up to have a look Share this post Link to post Share on other sites
