shootinok 15 #1 Posted March 27, 2011 Where's the best place to buy parts? I need gaskets for the Hydro transmission on my C-121 Also need a new clutch plate for the PTO - can you still get these? Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #2 Posted March 27, 2011 A Toro dealer - local or online - is the only source of most parts for the tractor itself. Depending on what gaskets you need, you'll either have to get them through Toro (transaxle case and hydro motor to tranz case), or contact a shop that carries/services Sundstrand hydro units. (pump and motor gaskets, seals, o-rings, etc.) I believe this company is still handling parts for the Sundstrands used in WH tractors: (It's quicker to add this direct link than to try to lead you to it in the RedSquare links section) BJ Hydraulics Share this post Link to post Share on other sites
shootinok 15 #3 Posted March 27, 2011 Thanks TT Looks like I can find almost everything I need.... Not able to find the gaskets for the lower part of the transmission. Part Numbers are 200191 (gasket - motor) and 200223 (gasket - pump) anybody got 'em :thumbs: Share this post Link to post Share on other sites
