kthack657 279 #1 Posted March 9, 2011 Hi all, I got my charger 12 up and running and got to take him for a ride, but I noticed a noise from the transmission that sounded like its growling...Has anyone else had this noise knowor what is going on? I hope the fix is easy and not a bad transmission. :thumbs: Share this post Link to post Share on other sites
smoreau 658 #2 Posted March 9, 2011 just a thought. Did you check to trans oil level? My electro 12 has a leaking housing and when its low it does growl a little . check that first :thumbs: Share this post Link to post Share on other sites
kthack657 279 #3 Posted March 9, 2011 We did check before the ride and it was a little low, but after doing some research I think I put the wrong fluid in...We thought we needed hydro fluid, but read that I need auto trans fluid... :thumbs: Share this post Link to post Share on other sites
dgoyette 12 #4 Posted March 9, 2011 Drain it and start fresh...if it comes out mostly red use Dexron III, if it looks like it was filled with motor oil use 10w-30. Share this post Link to post Share on other sites
mavfreak 11 #5 Posted March 9, 2011 You may want flush it out with some diesel fuel before you replace. Also replace filter Share this post Link to post Share on other sites
kthack657 279 #6 Posted March 9, 2011 I will definately drain and start fresh, does anyone know how many quarts it takes, I want to make sure I do everything correct, I want this horse to stop kicking and screaming and finally start to cooperate! :thumbs: Share this post Link to post Share on other sites
