stevebo-(Moderator) 8,364 #1 Posted March 7, 2011 All- I have a bunch of NOS and slightly used parts that I looked up on Partstree and could not find. If you could help me with a good source to research them that would be great. Once I figure out what they are I will list most if not all for sale here first. Thanks- Here is the start of the list I have 105074 mower deck spindle (metal older style) (I have spindle bushing for this one too -no part number) 8389 mover deck spindle (metal older style) 6403 left side fot pedal (clutch/brake?) 103599 or 589 left side clutch pedal (used) 5640 lift lever housing? I have two - one is nos and other is used 5797 smaller tie rods (I have 2 of them) 105 147 bracket? 225407 bracket 225407 round hollow shaft with holes 102781 nos gear 9295 mower deck bracket ? 8890 some type of selector (I have 3) 5786 triangle shaped bracket with 1 grease fitting 7701 looks like 3/4 shaft 7587 bushing ? 102691 short shifter? 100329 looks like a small sized coil bracket 104729 Looks like pto part 6072 possible 3 point clevis 7584 shaft with thread on one end 9296 possible wrong number -pto bracket? 102569 3 point cat 0 pin? 104855 throttle cable bracket? 9797 says dozer hook 6745 angle bracket 102861 some sort of flat spring ? 108384 bracket Share this post Link to post Share on other sites
Jim_M 178 #2 Posted March 8, 2011 Try this Steve. Go to parts, then use Toro consumer equipment, I looked up a few of your part numbers, not all, but it found the ones I looked for. http://www.milacalawn.com/parts.asp Share this post Link to post Share on other sites
stevebo-(Moderator) 8,364 #3 Posted March 8, 2011 Thanks Jim. Is there anyway to cross the part to the tractor or implement with this site? Share this post Link to post Share on other sites
Kelly 1,030 #4 Posted March 8, 2011 Yes I just went through most of your list, click on the part no. that best matches what it is, and on the right a list will so what it fits. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,364 #5 Posted March 8, 2011 Thanks Jim and Kelly. I just did the same thing. Share this post Link to post Share on other sites
