rob65
stainless tie-rods
rob65
Where can I get stainless tie rods for my 312? I don't have access to machine tools to make them myself. Thanks.
tarcoleo
Rob-
You will need a vice, a threading die, and a hacksaw to put together stainless
tie rods of your choice. All the parts and materials you need are at-
http://www.mcmaster.com/#
Good luck,
Tom in RI
rob65
Rob-
Good luck,
Tom in RI
I was hoping to get something prefabricated. I'm sure I could find the rod ends, I think I'd like the rods turned on a lathe. I thought I saw a post with someone who had some made up, for sale.
hoser63
i see that "buckrancher" posted pics of ss tie rods he made on his restoration post.....if that helps
tarcoleo
Rob-
Buckrancher's De Lorean "WH" uses flat SS barstock for tie rods, no lathe
turning here. Rob, what's there to lathe turn on a tie rod? Rod is round is
round is round and it comes that way. Am I missing something in your intent?
Tom in RI (Little Compton) :thumbs:
VinsRJ
I've purchased a couple things from Buckrancher and they have been top notch!
rob65
I was thinking of using hex stock faced to length, spot drilled, drilled & tapped for the female tie rod. Faced to length, turned & threaded for the male. Simple lathe part.
I would use hex stock to lock the lam nuts with a tab washer. Maybe I'm reading too much into what I see here on the stock tie rods, they look like they could be improved greatly.
