stevasaurus 22,878 #26 Posted October 2, 2013 How do the ends of the 11/44 gear look??? That is the big mushroom gear that rides in this hole. I have a feeling that the bottom part of the shaft is chewed up also. Talk with you later...call anytime today. Share this post Link to post Share on other sites
waynen 0 #27 Posted October 3, 2013 Here is a photo of the end of the shaft that sits in the hole, not a close up but is the only one I took at the time. It doesn't look perfect but I would have expected it to look worse given the condition of the side of the case that I posted previously. Share this post Link to post Share on other sites
AMC RULES 37,134 #28 Posted October 4, 2013 Curious... could internal damage similar to that shown here cause the end of axle seal(hub end)to start leaking? Share this post Link to post Share on other sites
