dgjks6 6 #1 Posted February 20, 2011 How do I remove the black "T" knob from the end of the throttle and choke lever so I can get the face plate off? Share this post Link to post Share on other sites
smoreau 658 #2 Posted February 20, 2011 :thumbs: should just pull off. it may have been glued but all mine just pulled off the steel lever. :thumbs: Share this post Link to post Share on other sites
JimD 3,345 #3 Posted February 20, 2011 I use pliers. Put them right behind the knob, up tight against the plastic, get a good grip on the metal arm, and pry away from the dash panel. It should come off in a few tries. Share this post Link to post Share on other sites
Fiscalyear 0 #4 Posted February 20, 2011 With my luck I would break something and have a hard time finding a new part. Have you considered disconnecting the ends and removing the complete assemblies from the machine? I'm curious how this ends up for you. Please post your procedure and results. Eddie Share this post Link to post Share on other sites
TT-(Moderator) 1,145 #5 Posted February 20, 2011 Use a claw hammer - with a piece of wood against the plastic dash panel to protect it. Share this post Link to post Share on other sites
dgjks6 6 #6 Posted February 20, 2011 I hate unfinshed posts - so thanks - I got it. Claw hammer and some force worked. The dash panel is being replaced so I had to get them off - and no wood needed because dash panel getting replaced. Share this post Link to post Share on other sites
Kelly 1,030 #7 Posted February 20, 2011 Remember if you break them or just need some Glen in the vendors section makes and sells new ones. Share this post Link to post Share on other sites
JimD 3,345 #8 Posted February 20, 2011 TT, I like your idea better. Less damage to the knob and/or dash plate. That's going in the "bank". :thumbs: Share this post Link to post Share on other sites
rmaynard 15,727 #9 Posted February 20, 2011 There was a thread last April on the same subject. I posted a picture of how I did it. Here it is. Clamp a vise-grip onto the lever, just far enough back so as to be able to slide a pry bar, or as TT said, a claw hammer, between the vise-grip and the plastic handle. Give it a little push and it should pop right off. Share this post Link to post Share on other sites
rracioppi 2 #10 Posted July 28, 2015 Thanks Bob it worked great Share this post Link to post Share on other sites
