closha63 0 #1 Posted February 4, 2011 Ok well I purchased the Charger from a friend and he forgot to mention that the trains is leaking something terrible. I think that its leaking from the pump but im not to sure and I can not tear it down yet due to having to plow the oncoming snow. Can anyone give me some insight on where to start for when i do pull it. I would like to just pull it out and re-seal it. Are their kits for the o-rings and seals or do you have to purchase them separately? What would you guys do??? Share this post Link to post Share on other sites
B-8074 19 #2 Posted February 4, 2011 Not sure about overhaul kits but I would clean it off real good and check it over. There are a few screw in plugs that may need tightened up. :thumbs: Share this post Link to post Share on other sites
closha63 0 #3 Posted February 5, 2011 Would anyone happen to have pictures of where the plugs / screws are that will need tightened? Has anyone posted pictures or a procedure on how to remove and tear down these trans. Share this post Link to post Share on other sites
KB9LOR 4 #4 Posted February 5, 2011 You have the 5062 Tranny, follow the link below, in the top space put in your model number, put "none" in the second blank, it will then show the manual you can download for the tranny, yours is a Sundstrand. https://lookup3.toro.com/request/request.cfm Share this post Link to post Share on other sites
can whlvr 993 #5 Posted February 5, 2011 if its leaking from between the pump and transaxle u might be able to get that gasket,i made my own because the dealer had to wait 2 weeks 4 one,i got the material from a hydrolic shop,i did get the proper gasket but have not put it in yet,as mentioned u need to clean it and look where its leaking from first,maybe a loose hose,or does it have an axle seal blown Share this post Link to post Share on other sites
