KB9LOR 4 #1 Posted February 1, 2011 Could not get any bites on this in my other thread so I split it up....I have a 69 Electro 12, can the Lift control Valve be rebuilt? Thanks, Share this post Link to post Share on other sites
KB9LOR 4 #2 Posted February 2, 2011 Well going to tear into the control valve in the morning, that's IF i have power in the shop....lol Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #3 Posted February 2, 2011 If you can get it apart, it can probably be resealed. I know the newer control valves are serviceable (and seal "kits" are available), but I have never messed with the old ones. Share this post Link to post Share on other sites
KB9LOR 4 #4 Posted February 2, 2011 If you can get it apart, it can probably be resealed. I know the newer control valves are serviceable (and seal "kits" are available), but I have never messed with the old ones. Man! that stinks, seems everything on this is not rebuild friendly, If it is a sealed one, I am going to either make it a manual lift or find a c121 with Hyd lift and use it as a donor tractor, this Electro is too nice to part out. I have to fix it! Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #5 Posted February 2, 2011 Try this: http://www.wheelhorseforum.com/index.php?showtopic=25151 I'm sure someone has a working control valve they'll sell. Share this post Link to post Share on other sites
KB9LOR 4 #6 Posted February 2, 2011 Try this: http://www.wheelhorseforum.com/index.php?showtopic=25151 I'm sure someone has a working control valve they'll sell. Sent him a e-mail, will update this post when and if I get it fixed or replaced, thanks for all your help! It is very much appreciated! Share this post Link to post Share on other sites
KB9LOR 4 #7 Posted February 8, 2011 Got a small update, Went to the Hydraulic Shop today after work, Owner working told me easy fix on the seals, told me they should not be much(Price wise), if so I am going to pick up a bunch and then will have some on hand for the next guy to fix his Valve. And found the Owner has some old Single Thumper Cast Iron Briggs engines he is wanting to part with 16hp and down, Plus a 16hp twin eactly like the one in my GT-1642 now! Man can you say what luck! Share this post Link to post Share on other sites
can whlvr 993 #8 Posted February 8, 2011 right on,hope the seals work good 4 u Share this post Link to post Share on other sites
KB9LOR 4 #9 Posted February 8, 2011 Well got bad news today, his supplier does not carry that small of a Buna seal. he could not figure out if it was Metric or SAE! So back to square one! SAE 1/2"OD X 1/16"X 5/16ID Metric 2-1/2 mm Tall x CS=2mm x ID=7.5mm OD=12mm Share this post Link to post Share on other sites
Indy w h 5 #10 Posted February 9, 2011 Brian, I'm going to town in the morning so I'll stop by my supplier and see what he has. How many seals do you need for this?? Indy Share this post Link to post Share on other sites
KB9LOR 4 #11 Posted February 9, 2011 Brian, I'm going to town in the morning so I'll stop by my supplier and see what he has. How many seals do you need for this?? Indy Indy, at least 2 for myself, and if everything goes good with those, I will buy xtra's! and thanks! It is much appreciated! Share this post Link to post Share on other sites
Indy w h 5 #12 Posted February 9, 2011 Brian , PM sent Indy Share this post Link to post Share on other sites
KB9LOR 4 #13 Posted February 9, 2011 Brian , PM sent Indy Indy, returned PM.... Share this post Link to post Share on other sites
