Guest Kuvasz101
Limited slip differential
Guest
I have a 1992 416 8 speed. How would I know if it's a limited slip differential? There is no model number or serial number. The rear wheels take turns spinning but once and a while both will spin together. Thanks
stevasaurus
:ROTF: You got him TT?? :thumbs: I would have to look it up, and you got it in your head. :banghead:
TT
If it's the original #110995 tranz, it has 8 pinion open differential with 1 1/8" axles. The "Trans-Power" 10 pinion differential was only used from 1967 to 1973 - and not in all models.
:banghead:
can whlvr
jack up the tractor in the rear,spin the wheels by hand and if they move the same direction its a posi,i doubt it though,they will probally spin one forward one reverse and thats not a posi rear end,from what ive learned here u probally dont want a posi rear anyway
VinsRJ
:banghead:
:thumbs: of course! :ROTF:
