kpthorsefan
DECAL HELP
kpthorsefan
Hi all, I have nearly finished my snow plow for my C-141, its a 42" and has no id tag on it. what i would like to know is what decals where on it ? Some pics would be a great help to see if i can get them made. Many thanks kevin..
meadowfield
from the UK ones I've seen it's usually a red with white writing WHEEL HORSE. Same as the rear fenders on mid 70's raiders and C series - 307x30mm is the usual size.
mark
kpthorsefan
mark
Thanks for that mark. I also think there was a caution decal on there as well, when i took it all apart the decals were to far gone to read properly :banghead:
Anglo Traction
Hi Kevin, You could try looking in the Implements Picture Gallery for some examples and perhaps contact the Member to obtain an image of the Caution Label. Mark is correct with the W/H Decal Style for your age of Blade/Frame. It is applied top left of the back of the Blade. Caution Label on the Right from what I can see.
TT
Since you aren't sure what year your dozer blade actually is, (they're pretty much the same) I would match it to the generation of your tractor. (the same as the original rear fender decal on the C-141)
Some of the original "Caution" decals were quite large - and a bit ugly. :banghead:
P/N 113915 appears to still be available from Toro. ($6.00 here in USA)
Hard to see well in this photo:
....but can be read here:
squonk
Here's some pics of the decals on my plow. It's off of a Raider 12 and now on my C-160. Most of the WH decal flew off when I hit a sidewalk at speed! :banghead:
kpthorsefan
Hi richard, I have had a look through picture gallery and cant seem to find any, but many thanks..
meadowfield
If I can get the decal dimensions for the caution, then it's no trouble for me to reproduce if you are looking to renovate...
mark
kpthorsefan
kpthorsefan
TT
Hi Terry, The warning decal looks spot on :banghead: . would you happen to know the size and colour of it ?
I no longer have that dozer blade and my newer one (1995) doesn't have the warning decal.
I would guess it to be something like 2" high X 5" long and the base color is white with red print.
The decal on Mike's ("squonk") blade should be the same as the early C series rear fender decal.
1.125" high X 12.125" long should be the dimensions.
kpthorsefan
mark
Pm sent..
kpthorsefan
Hi Terry, The warning decal looks spot on :thumbs: . would you happen to know the size and colour of it ?
Many thanks for that terry :banghead:
