CTPATRIOT 12 #1 Posted January 3, 2011 My new 877 hydro has a small(i hope)problem.The hydro lever has no tension to keep it in place(for./bac.).Is there an adjustment i can make,or tighten??? Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #2 Posted January 3, 2011 The only friction adjustment on the '65-'67 hydros is the screws/springs/tension plates that secure the nylon cam plate at the front of the pump. Clean everything and install a new cam plate (#5996) DRY (no lubricant) and see if that helps. Don't overtighten the screws. The first generation hydros are a little quirky & jerky, but you'll get used to it. :ychain: Share this post Link to post Share on other sites
