rrbattani 0 #1 Posted December 25, 2010 I just recently acquired a '90 520h. When I bought it, last week, the hydro was very strong and responsive, and the lift worked great. I got it home, and on a cold start, (below 40 degrees) the lift doesnt want to operate, and the tractor moves very slugishly. Once it has moved 50 feet, the hydraulics work just as they should, and the tractor moves foreward, and reverse just as it should, and is very strong. This is puzzling to me, as it is just the opposite as most failing hydro's, that work good cold, and fail as the get hotter. Does anyone have any suggestions where to start looking for the cause? Fluid and filter were changed while I was picking it up, and it was a toro filter. Could it maybe an oil viscosity issue? I do not know what of oil they used when it was serviced. Share this post Link to post Share on other sites
rmaynard 16,449 #2 Posted December 25, 2010 Toro recommends 10W30 or 10W40. Could be that it was serviced with the wrong fluid. Just a guess on my part since I don't have any hydro experience. Bob Share this post Link to post Share on other sites
Sparky-(Admin) 23,516 #3 Posted December 25, 2010 The hydro tractors are supposed to be allowed to "warm up" for a few minutes before using them. My 416-H needs a few minutes in the winter before it will operate as it should. Your 520 is fine. Mike......... Share this post Link to post Share on other sites
Kelly 1,033 #4 Posted December 25, 2010 All 3 of my 520's need a few min. to warm up, it's in my opinion best to let them warm up, before working them, and it gives the engine time to warm up, Onans are not cheap to repair, so a few min. warming up might save a few dollars down the road. Share this post Link to post Share on other sites
Operator 7 #5 Posted December 25, 2010 I kind of figure it is a good idea to warm them all up a little. I know it takes me a little to get going in the morning. Randy Share this post Link to post Share on other sites
MalMac 1,333 #6 Posted December 25, 2010 I have a 90 520h and like everybody else said it has to warm up. Mine won't even move or the hydraulics function for 10min. after startup even longer in sub zero wheather. you can cause alot of damage forcing the issue. Share this post Link to post Share on other sites
WheelHorse_of_course 99 #7 Posted December 26, 2010 Read your manual. It probably says that you MUST let it warm up (e.g. with hydro engaged/parking brake off) or damage may occur. So, as other have said, no bad news here! :ychain: Share this post Link to post Share on other sites
HorseFixer 2,013 #8 Posted December 27, 2010 Try Switching to Synthetics Dino oil freezes solid at 50 deg below zero. Now yes I realize we don't get 50 deg below zero but when it is say 0 deg oil flows like Tar leaving your engine or in this case transmission starving for oil until it warms up, and thats where the most wear comes from over the life of an engine. At a -50 AMSOIL still pours. Don't be confused with viscosity, & pour point. You cant expect sludge that is pumped from the ground then refined to match the lubrication abilities of Synthetic oils that are designed for a specific purpose. Yes it costs more...... Or does it? if your mechanical equipment gets lubrication when it is suppose to the moment it is turned on it only makes sense that less wear will accure over the lifetime of the equipment. And oh by the way.... Last year was the first year that I owned a Hydro (Snow Chucker) and all the lubricants were change to synthetics. I left the machine outside at below zero one night last year, next morning came out started it up and within 15 seconds moved the tractor with no ill effects! Do yourself a favor and switch AMSOIL I'm sure there is a dealer in your area if not you can get it off my website either way I will help ya. Many people on here contact me and I spend time answering their questions wether they buy it from me or elsewhere all that matters to me is that guys are protecting their equipment! ~Duke AMSOIL Oil Comparisons Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,596 #9 Posted December 28, 2010 There is a 1996 product service bulletin on 1988-1994, and part of 1995 Eaton 1100 cold loss of prime. It is in http://groups.yahoo.com/group/wheelhorsetractormanuals8/ and named Toro91-presGT #GT19 Eaton 11 Transmission Cold prime loss Garry Share this post Link to post Share on other sites
pfrederi 18,806 #10 Posted December 28, 2010 From the Service Bulletin A loss of prime condition is indicated when the tractor fails to move in forward or reverse, after a cold start-up. This should not be confused with the operation of the hydraulic lift system, which typically takes several minutes to begin operating in cold weather. My 418A refuses to pick up her snowblower for awhile after start up. Makes it hard to get her out of the shop to warm up. I may have to but it on a 8 speed tractor next year... Share this post Link to post Share on other sites
wheelhorse656 20 #11 Posted December 28, 2010 all the hydros i have ever used need a few mins to warm up in the winter. Share this post Link to post Share on other sites
can whlvr 994 #12 Posted December 29, 2010 i do let my 1975 c160 warm up,good for the seals,but i live in ontario and it gets cold up here,i left it uoyside one night and the temp was -28celcius,dam cold,the tractor will move instantly and the lift works immediatly also,i dont do this often but it amazes me how fast this machine works in the cold,its a sundstrand not an eaton. Share this post Link to post Share on other sites
Forest Road 594 #13 Posted December 30, 2010 Do you get in your car on the coldest of days start it up and take off immediately? Probably not. Same goes for for your labor saving WH. Give it a bit to warm up. You'll be glad you did. Share this post Link to post Share on other sites
WheelHorse_of_course 99 #14 Posted December 31, 2010 i do let my 1975 c160 warm up,good for the seals,but i live in ontario and it gets cold up here,i left it uoyside one night and the temp was -28celcius,dam cold,the tractor will move instantly and the lift works immediatly also,i dont do this often but it amazes me how fast this machine works in the cold,its a sundstrand not an eaton. Does it have Dextron or 30 weight in the trans? My previous research seems to show that prior to the changeover to 30W the manuals did not have the advice to warm up the trans before using. :ychain: Share this post Link to post Share on other sites
Brandonsj04 0 #15 Posted December 31, 2010 I also have the 520h and most if not all days you will have you will have to wait for the hydro system to warm up. Other times it works right out of the gun for no ryhme nor reason. This also happens in the fall as well with temps around 40-45. Good luck, you'll love the tractor :ychain: Share this post Link to post Share on other sites
kadetklapp 1 #16 Posted July 29, 2011 Old thread, I know, but has anyone tried putting a magnet mount "block heater" on the hydro overnight before say getting up in the morning to plow? I think I may do this to save wear on my tractor this season. Share this post Link to post Share on other sites
illinilefttackle 399 #17 Posted July 29, 2011 Old thread, I know, but has anyone tried putting a magnet mount "block heater" on the hydro overnight before say getting up in the morning to plow? I think I may do this to save wear on my tractor this season. I leave a small electric heater on in the garage on the floor directed at the rear of the Tractor ( C-125A ) -even just on the low setting, the tractor warms up a lot quicker on cold morning plows- but I still warm it up at least 3-4 min with pump engaged-Thanks-Al Share this post Link to post Share on other sites
shorts 182 #18 Posted July 30, 2011 synthetic oil is a good thing for hydrostatic transmissions, it keeps them lubricated when cold and flows instantly on startup, but they still need to warm up in cold weather, a good rule of thumb is if the engine still needs the choke and or high idle to run right it's to cold to work the tractor Share this post Link to post Share on other sites
Hydro 131 #19 Posted August 3, 2011 In the manual I had for my 416H it definately warned that damage could be caused to the unit if you did not let the hydro warm up. I do not know what damage that could be but it was there in black and white. Since the valve guides went I acquired a JD 260. The manual says nothing about winter temps. At this point I don't know if the warm up is unique to the W/H or just that the JD design is not so critical. :woohoo: Share this post Link to post Share on other sites
can whlvr 994 #20 Posted August 4, 2011 any hydro tractor,skidsteer,backhoe etc,should have a warm up period,in winter i run my skid steer for 5 min before i move it Share this post Link to post Share on other sites
Kevin Bowley 140 #21 Posted September 4, 2011 Last year I decided I was going to standardize my oils as I have to many tractors. After a ton of research I settled on Mobile One 0w40. I use it in all the trannies, Hydros and engines. While Amsoil is an outstanding product, they did not have a product as diverse as the Mobile One 0w40. It meets/exceeds VW 502/505 spec'd as well as nearly every other OEM cert. It is the finest product they make save the VW 507 spec'd EST. The VW 507 is considered the toughest requirements out there but that oil is foolish money and very hard to acquire. Currently only the VW dealers and some online stores carry it for the new direct injected TDI engine. The Mobil product has been epic in every way. I have done several oil analysis done after 40 hours in splashed lubed engines as well as sunstrands and a couple of Vanguards and it does not shear down . It stays in grade with almost nil wear and they recommend extending to 60 hrs, which I dont feel comfortable enough yet. Just pushing from 25 to 40 hrs was enough for me. The engine turns over as if it were 80 degrees when the temps are very cold and the hydros are silent and strong. Great product and I highly recommend giving it a try. If you wish to become very educated about lubrication I suggest www.bobistheoilguy.com its very interesting reading and they have a small engine form that is extremely active. Kevin. Share this post Link to post Share on other sites
ericj 1,579 #22 Posted September 6, 2011 i have several tractors with the Eaton 11 trans. most move almost immediately unless real cold. but i have a 93 520-H that unless it is above 65 degrees or so won't move for several minutes. The deck will actually drop if deck is up and you hit the lift handle even to the up position. and the other odd thing about this particular tractor is that it pushes very very easily with out the usual tic tic noise you get when the tractor is hand pushed. I've got oil and a Toro filter to change the rear oil, but i am thinking about adding kero. or something to clean and possible degunk the trans. although the oil in it look good. I've considered a trans swap, but have always been told the 520 trans are almost bullet proof. Hate to spend the money on the oil change and then have to tear it apart to repair or replace. this tractor take so much longer to move than my other tractors. Share this post Link to post Share on other sites
CRE1992 135 #23 Posted September 6, 2011 DO NOT RUN KEROSENE IN THAT TRANS! you may ruin the pump! Share this post Link to post Share on other sites
can whlvr 994 #24 Posted September 6, 2011 i agree,if it works like the sundstrand tha pump uses the same fluid as the rear end which means you will be running kerosene in the pump which i would NOT do if i were you Share this post Link to post Share on other sites
