CTPATRIOT
Bronco 14 trans fluid?
CTPATRIOT
Wondering what fluid my "71 Bronco Automatic takes?
rickv1957
AtF was original,motor oil was later,check what you have and replace with same,Rick
WheelHorse_of_course
To clarify, the ATF will be red. If so use Dextron III (was originally "type a" but that no longer exists and Dextron is the replacement.
:D :ychain:
