rocking 416 1 #1 Posted May 2, 2008 i have 1996 416 hydro the brake pedal works but dosent want to return the spring is in tact i assume its in rite place an it has been greased before Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #2 Posted May 2, 2008 Try unhooking the rod from the pedal to see if the pedal moves freely. If the pedal isn't the source of the problem, start investigating at the brake band mounting bracket pivot and the "return to neutral" cam plate and related linkage from the brake pedal rod to the direction control cam. Share this post Link to post Share on other sites
