squonk 42,335 #1 Posted December 14, 2010 I'm looking at the manual to adjust the neutral adjustment on My C-160. It mentions the lobe on the eccentric pin must be upward for proper operation. While working on my linkage trying to cure an erratic hydro I took the nylon cam off and spun that pin around a few times looking for something wrong. This is BEFORE I received the instructions on how to do it. I did not operate the tractor after reassembly and tonight I took out the accel valve spring and checked for damage. I put it back together and the trans works better but I still need to do a neutral adjustment. My question is what problems are caused by having that eccentric pin in the wrong position and maybe moving it cured some of my problems? Share this post Link to post Share on other sites
