JMW 3 #1 Posted December 8, 2010 I don't know if this is possible but here it goes.I'm building a c-160 puller for my 10 year old and it has separate clutch and brake pedals.Is it possible to make it a one pedal clutch/brake setup like my old raider 10 ? I would like to put a foot throttle on it for him.I still have a raider trans. for parts if needed.If anyone knows if it is possible please let me know.Thanks, Jim. Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #2 Posted December 8, 2010 Yes, it is possible. Set it up exactly the same as the Raider. Share this post Link to post Share on other sites
JMW 3 #3 Posted December 9, 2010 Thanks I'll get em side by side and start changing things.Appreciate the help. Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #4 Posted December 9, 2010 Most of the work will be removing all of the brake pedal pieces. The cast clutch "arm" (where the rod from the clutch pedal is attached) probably already has the second hole for the brake rod, so all you'll need to do is find (or make) one and connect it between the clutch arm and the brake band. :ychain: Share this post Link to post Share on other sites
