ftlboy717 0 #1 Posted December 2, 2010 hello, can any one help me out i have a raider 12 with a 14 hp motor i need some diagrams for the pto setup for rear tiller. i also need to see some pics on what engages the pto on the raider 12,since i have the 14 hp engine i think it may be diifernt sedtup for the engine than what my tractor is to have,i have the handle that mounts on the right side to engage the pto i think but i have been seeing a lever set up does any one no which one i will need or if it will work with me haveing the 14 hp motor? im guessing the raider 12 is to have a 12 hp on it not a 14 since my engine hangs over the frame on the right side and has a generater/starter rather than the normal starter that goes on the fly wheel, thanks here are the pics of my crank wear the pto should be,the other pics are the day i got the tractor i had to put on a new dash,seat and redo the whole wireing harness,and last is a pic after paint and some new parts,its a little dirty it was in use that day Share this post Link to post Share on other sites
ducky 1 #2 Posted December 2, 2010 i hope these help u out. fun chatting with you. here is the pic of the dash. and the pto stuff Share this post Link to post Share on other sites
racinfool40 202 #3 Posted December 2, 2010 Her's a pic of my raider 12 by the looks of your pic your gonna need the correct pulley also the pulley should have 4 holes the friction disc mounts to. Also the 10-12-14-16 hp Kohlers sit off the side of the frame 2 bolts come up from the bottom and bolt into the oil pan. If it has the correct oil pan: If you need the right pulley I do have an extra on and if you need the rest of the PTO assm post it here in the wanted section and if that fails you can pick them up on Evil-bay quit reasonable. Have any other questions please fire away!!! Mike.... Share this post Link to post Share on other sites
squonk 41,887 #4 Posted December 2, 2010 Those AG's with chains are on backwards or was that done on purpose? :thumbs: Share this post Link to post Share on other sites
ftlboy717 0 #5 Posted December 3, 2010 thats the way they came when i got the tractor, that is the pic of it the day i got it, i was told it gives better traction,but i did turn them around,that was one of the first things i did Share this post Link to post Share on other sites
ftlboy717 0 #6 Posted December 3, 2010 Her's a pic of my raider 12 by the looks of your pic your gonna need the correct pulley also the pulley should have 4 holes the friction disc mounts to. Also the 10-12-14-16 hp Kohlers sit off the side of the frame 2 bolts come up from the bottom and bolt into the oil pan. If it has the correct oil pan: If you need the right pulley I do have an extra on and if you need the rest of the PTO assm post it here in the wanted section and if that fails you can pick them up on Evil-bay quit reasonable. Have any other questions please fire away!!! Mike.... i orderd the pto setup from ebay shld be here tomoro,but it came with the half moon rod i was told this is for newer horses,the only thing i need is the shaft that my pto rod hooks into the one that bolts to the block if i cant find one im going to try n make one, buty ne way once it gets here i may need some parts ill get back with you as soon as i get it,thanks o and do you have any more pics of your raider id love to see more it looks nice i like the black and red Share this post Link to post Share on other sites
Kelly 1,030 #7 Posted December 3, 2010 The newer style PTO will not bolt right on, you will need all the PTO parts, arms, levers, links, frame and engine brackets, from a solid mount engine tractor, ect.... every piece from the dash out, then you will have to drill the dash tower to put the PTO engagement arm in, the rest will bolt on, I have a electro, that has been converted, or was I removed it all. Share this post Link to post Share on other sites
Kelly 1,030 #8 Posted December 3, 2010 And you will need the correct engine pulley for the PTO to fit, I have all the parts you need to put the newer style PTO on if you want send me a PM. Share this post Link to post Share on other sites
racinfool40 202 #9 Posted December 3, 2010 Here's some more pics I dug up This is my favorite tractor and my 1st one!!My Dad bought this new in the fall of 1969 right after I was born: It came with a 12hp tecky but that blew about 3 yrs ago and i put on the 12 kohler best move I ever made!!!It's never failed me!!!! Share this post Link to post Share on other sites
