MikeD0371
8 speed ?'s
MikeD0371
again have a 77 b100 8 speed, need to change a axle bearing an seal, are these pressed in? can i change with out cracking the case? an all else fails will my 310-8 tranny work as a replacement. thanks guys
sorekiwi
You can change the seal without splitting the case, but you'll need the axle out to change the bearing.
rmaynard
The seals can be replaced without opening the case, however the case has to opened to replace bearings.
I don't know for sure about the 310-8. There should be someone that will come along and give you a definite answer.
Bob
TT
Ditto
