MikeD0371 0 #1 Posted November 30, 2010 again have a 77 b100 8 speed, need to change a axle bearing an seal, are these pressed in? can i change with out cracking the case? an all else fails will my 310-8 tranny work as a replacement. thanks guys Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted December 1, 2010 You can change the seal without splitting the case, but you'll need the axle out to change the bearing. Share this post Link to post Share on other sites
rmaynard 15,890 #3 Posted December 1, 2010 The seals can be replaced without opening the case, however the case has to opened to replace bearings. I don't know for sure about the 310-8. There should be someone that will come along and give you a definite answer. Bob Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #4 Posted December 1, 2010 Ditto Share this post Link to post Share on other sites
