MikeD0371 0 #1 Posted November 30, 2010 so i have a bearing on left side of tranny bad, or gone, how do i get the hub off, took set screw out, that it? bfh?? big fu@kin hammer??? Share this post Link to post Share on other sites
btrrg1969 11 #2 Posted November 30, 2010 lots of penetrating oil , patience , a puller , be careful the hub will break. It took me about an hour for each hub Share this post Link to post Share on other sites
Duff 206 #3 Posted November 30, 2010 so i have a bearing on left side of tranny bad, or gone, how do i get the hub off, took set screw out, that it? bfh?? Share this post Link to post Share on other sites
rmaynard 15,890 #4 Posted November 30, 2010 I had some stubborn hubs on my B-100. Here is a hub puller that I made. It is made from a 1" hub, a 1" bolt and nut, five 3/8-16 all-thread bolts, 10 nuts, 5 lock washers, and 10 flat washers. It took over one hour of 1/4 turn on each nut, over and over again. Lots of PB Blaster, a Mapp gas torch, and a big hammer to hit the 1" bolt every now and again. Bob 3 Share this post Link to post Share on other sites
1961551 2 #5 Posted November 30, 2010 like duff said, be patient. i have seen a few that the woodruff key gets loose and actually expands the axle material around it. can be a bear to get off. obtain a quality puller. if you have heat to apply, thats a plus. but, the hubs are cast and are brittle. be carefull. do not strike hub with hammer. jimmy Share this post Link to post Share on other sites
MikeD0371 0 #6 Posted November 30, 2010 Thanks for the fast reply guys as always many thanks to you all for helping me out Share this post Link to post Share on other sites
