brianf 0 #1 Posted November 22, 2010 I'm in the middle of this 1267 / 5060 unidrive rebuild. I acquired two new axle bearings (actually both inner and outer..but here I'm talking about the outers). As I was looking at them, I noticed that one of them has a carrier in it and the other one is just the rollers like my original ones where. I know that more rollers = more weight capacity, so should I try to find another one without the carrier or do the experts here think it's fine? I do quite a bit of pulling trailers (moving my boats around the yard) and snowblowing with this machine. Share this post Link to post Share on other sites
stevasaurus 23,041 #2 Posted November 23, 2010 I feel bad when some one posts and no one answers in a certain time frame. I am not sure what you are talking about, which is maybe why no one answered. Is there a sleeve inside of one of the bearings that a shaft would fit through.??? Is that what you mean??? If it is, then I would go with the same kind that you took out. Does that make any since?? Again...pictures would be great. :thumbs: Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #3 Posted November 23, 2010 He's talking about a caged needle bearing, Steve. I've installed a few in tractors other than my own, so I really don't know how they've held up. @brianf: I don't really see what they'd hurt - and if you put enough weight on the tractor to crush axle bearings, you might want to think about buying something a little bigger. Just make sure the axles are in good shape where they ride in the bearings. Chatter marks or roughness on the axle surface will destroy the bearings too. Share this post Link to post Share on other sites
brianf 0 #4 Posted November 23, 2010 Yes a caged bearing is what I meant. I guess I'll try it out for now and just keep a closer eye one it. Share this post Link to post Share on other sites
