Tee 0 #1 Posted November 17, 2010 as a new guy here, now its my thinkin. i see wheel horses pull the sled and farm using implements, is there a special belt to use on these, seems with all the load the belt would squeal and smoke. and all traction lost to tires. thanks Share this post Link to post Share on other sites
Sparky-(Admin) 21,890 #2 Posted November 17, 2010 Actually the pulling guys have good luck with the belts. I do think they put a "stronger" clutch spring on their pullers tho. Mike....... Share this post Link to post Share on other sites
WH854 44 #3 Posted November 17, 2010 If you got a good belt on the tractor,the wheels most likely spin if the object you are hitched to will not move. Chas PS :) Share this post Link to post Share on other sites
Tee 0 #4 Posted November 17, 2010 as a new guy here, now its my thinkin. i see wheel horses pull the sled and farm using implements, is there a special belt to use on these, seems with all the load the belt would squeal and smoke. and all traction lost to tires. thanks thanks guys Share this post Link to post Share on other sites
