Andrewtw 0 #1 Posted November 10, 2010 I'm not going to say has anyone got a variable speed pulley for a RJ35 I know no one has any if they do there not gonna part one out just for that pulley! so can someone send me some close up pics of one all different angles! also diameter size width, shaft size inside where the center shiv slides ! gonna try to make one :thumbs: Share this post Link to post Share on other sites
clintonnut 126 #2 Posted November 10, 2010 I don't have dimensions but you can check around for the bolens version. It works on the Wheel Horse and is a little easier to come by. They do make variable pulleys without the reverser groove so you could probably machine the reverser groove and weld it to the pulley. Charlie Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #3 Posted November 10, 2010 http://www.wheelhorseforum.com/index.php?showtopic=22662 I saw one on a really rough RJ in "wheelhorsec85" Jeff's video. Couldn't hurt to ask, right? Share this post Link to post Share on other sites
stevebo-(Moderator) 8,398 #4 Posted November 10, 2010 I am sure it is for sale. Good thinking TT. Jeff has that as a parts tractor. You should be able to e tank that pulley and if not be able to use it you can use it for measurements. Good luck- Share this post Link to post Share on other sites
Coadster32 793 #5 Posted November 10, 2010 If you go with the bolens, it's called a ride-a-matic. I'd try Jeff first. Good luck. Share this post Link to post Share on other sites
VinsRJ 723 #6 Posted November 10, 2010 I've got an extra one. I can provide you with what you are looking for. I'm on the fence whether or not I would sell it. PM with your email. Share this post Link to post Share on other sites
