rmaynard 15,887 #126 Posted March 9, 2012 Denny, I need to order some new front tires for my Commando 8 and was wondering what you decided for your fronts? Size? Brand? I like the looks of whatever you have in this picture. Share this post Link to post Share on other sites
dclarke 4,055 #127 Posted March 9, 2012 Bob, those are the original 16 - 5.50 x 8 Wheel Horse tires. I put Miller's tire paint on them. Share this post Link to post Share on other sites
dclarke 4,055 #128 Posted May 27, 2012 Been waiting since December to get these back from the chrome shop. The hood ornament turned out really nice, wish I was ready to put it on. 1 Share this post Link to post Share on other sites
dyt4000 2 #129 Posted July 25, 2013 (edited) This is the n.o.s. deck shell I got from Scott, (whfan74) I had it blasted then installed all new bearings, seals and put a new set of blades on it. A new set of belts and it should be ready to go. Hello, Where did you get the bearings for your deck? I have the same one and will be rebuilding it this fall... Thanks, David Edited July 25, 2013 by dyt4000 Share this post Link to post Share on other sites
dclarke 4,055 #130 Posted July 26, 2013 This is the n.o.s. deck shell I got from Scott, (whfan74) I had it blasted then installed all new bearings, seals and put a new set of blades on it. A new set of belts and it should be ready to go. Hello, Where did you get the bearings for your deck? I have the same one and will be rebuilding it this fall... Thanks, David David, it's been a while since I rebuilt this deck but I think these are the correct numbers. The spindle bearings and seals I got from NAPA - Bearing number B1212 - seal number 7408....... The bearings for the pulley on the front of the deck I got from McMaster Carr - their part number 6384K47...... I also got the face gear shaft bearings from McMaster Carr - their part number 6384K79..... Hope this helps. Share this post Link to post Share on other sites
dyt4000 2 #132 Posted July 26, 2013 Is there a sticky for this awesome information about bearings for the older decks? Share this post Link to post Share on other sites
dyt4000 2 #133 Posted July 26, 2013 Seal 7408 is a match for McMaster 5154T56? Share this post Link to post Share on other sites
dclarke 4,055 #134 Posted August 11, 2013 I got new knives for my sickle bar and yesterday I found a buddy that has the tool to change them. Nothin to it once you get the hang of it. This thing shears the old rivets off to remove the old knife and punches the old rivets out of the bar. It also does a nice job installing the new rivets. 4 2 Share this post Link to post Share on other sites
bowtiebutler956 650 #135 Posted August 11, 2013 Very nice, I bet that thing would cut as good as the day it left the factory, now!! Great work! Matt Share this post Link to post Share on other sites
sorekiwi 761 #136 Posted August 12, 2013 (edited) I got new knives for my sickle bar and yesterday Where did you get the knives from Denny? Edited August 12, 2013 by sorekiwi Share this post Link to post Share on other sites
dclarke 4,055 #137 Posted August 12, 2013 (edited) Where did you get the knives from Denny? I got them and the rivets from Dale's mowing service in Kempton, Pa. Phone # 610 - 756 - 6453. I bought these knives a year ago, Mike. I assume this info is still correct. By the way, they are expensive. Edited August 12, 2013 by dclarke Share this post Link to post Share on other sites
dclarke 4,055 #138 Posted September 3, 2013 I'm back to work on this project now that my 701 is done. The sickle cutter bar that I put new blades on has been plated matte chrome. I bought a set of wheel weights last spring at Mentone, I got those blasted and base coated and a few tins and small pieces painted. Before I painted the seat pan I drilled holes in it so I could put springs under the seat for a better ride. I wanted a wider set of rear rims for the weights so I took all the tires back off and had the fronts and the wider rear rims powder coated and got those back on and last week I picked up an ST326 snow blower for this tractor. 2 Share this post Link to post Share on other sites
bowtiebutler956 650 #139 Posted September 3, 2013 That's coming along very nicely Denny! Those knives look fantastic, and so does the rest of it. Look forward watching the rest of this build! Matt Share this post Link to post Share on other sites
Terry M-(Moderator) 2,194 #140 Posted September 3, 2013 Yes, those knives do look nice Denny!! Can't wait to see the whole tractor done with the sickle cutter installed. Share this post Link to post Share on other sites
horsesaver98 18 #141 Posted September 4, 2013 what paint are you using Share this post Link to post Share on other sites
dclarke 4,055 #142 Posted September 4, 2013 what paint are you using I'm using Martin Senour base coat, the label from the can is on page 3 of this build thread. Share this post Link to post Share on other sites
dclarke 4,055 #143 Posted September 6, 2013 This is as it sits now, still waiting on the hood and belt guard to get blasted. I hope to have this done in time to take to Jacksonville but I'm running out of days fast. Tomorrow I should have everything painted but the hood and guard. 2 1 Share this post Link to post Share on other sites
bowtiebutler956 650 #144 Posted September 6, 2013 Looking really good!!!! Matt Share this post Link to post Share on other sites
welderman85 53 #145 Posted September 6, 2013 great work the sickle looks great Share this post Link to post Share on other sites
Terry M-(Moderator) 2,194 #146 Posted September 7, 2013 yes!, I agree Denny, sickle looks great on that Tractor. And I really like the wheel weights you installed. Share this post Link to post Share on other sites
dclarke 4,055 #147 Posted September 10, 2013 I've still got a few things to finish up on this but I'm finally getting close to being done. I discovered a pin hole in the gas tank, have to put a new diaphragm in the fuel pump and I still have to do the wiring and install the correct battery tray. 2 1 Share this post Link to post Share on other sites
MalMac 1,332 #148 Posted September 10, 2013 Looking good Denny, If only that Sickle Bar could talk, from where I got it, to being stolen from me, to me getting it back, to you getting it from me. I am glad you got it and restored it. Looks a whole lot better on a tractor than it did just sitting around here. You did good. 1 Share this post Link to post Share on other sites
dclarke 4,055 #149 Posted September 10, 2013 Thanks, Tim. It does have quite a story. Share this post Link to post Share on other sites
bowtiebutler956 650 #150 Posted September 11, 2013 I really like the sickle bar on there. Those things look very intimidating, they just scream keep all appendages clear! Matt 1 Share this post Link to post Share on other sites
